autostick conversion? - Page 2 - JeepForum.com
post #16 of 70 Old 01-25-2008, 01:53 PM Thread Starter
CharBroiled
Originally Posted by Gramps
No CVT2Ls have ever had the AutoStick option.
if its not an option, Id think the programming would never expect to be plugged into an autostick shifter and will always assume normal shifter.
that FD II TCU may never work with the autostick.
unless they plan to support it later, then they could flash it. can you tell if his TCU has the latest version?
if they plan to add autostick to FD II later there could be a slight chance it would work, maybe theres beta code supporting it in there now.
2000 Cherokee Sport 4.0L Selec Trac - mine - for occasional wheeling
2007 Patriot 2.4L FD I 4x4 - wifes - doomed to rarely leave the street
CharBroiled is offline
post #17 of 70 Old 01-25-2008, 02:40 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
That's what I've thought too.
Here's the latest on the FD II experiment after not having L or the gears displayed after the shifter and wiring additions.
Pulled the linkage off and shifted it to the L position the L came back. So the TRS controls the D and L and the sifter controls the 1-6. While it was in low I tried the auto shift no changes
Where we sit on this right now, other than trying to find a different part number for the AutoStick TRS (Trans Range Selector), I'm not sure.
to goebel1 over at JP for taking the time and effort to try this out!
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #18 of 70 Old 01-25-2008, 05:15 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Update:
goebel1 contacted the dealer and they said he would have to change to the TCM for the standard CVT2 and have it programmed with the VIN from one with the AutoStick option. He is then going to modify the shifter or create "something" that will engage L. I asked if reprogramming would wipe out the Off-Road features and he thinks that this is worth a try and if it doesn't work he can always put it back to what is was.
I guess that we're both hot rodders at heart.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #19 of 70 Old 01-25-2008, 05:49 PM Thread Starter
CharBroiled
in a FD I CVT2 I wonder if the same mechanical position that "L" would be in for the automatic would be the same as the +/- position for the autosticks. I mean the actual shift cable that runs to the actual tranny, the +/- position is the same as the "L" position. in a regular shift that position signals "L" for regular shifter and for autostick tells it to monitor for the + and - signals.
but in a FD II CVT2L that might be different. dunno.. just thinking out loud.. it seems its partly mechanical and partly electric..
post #20 of 70 Old 01-25-2008, 06:16 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
The bezels on the CVT2 & CVT2L have the same L gate which is higher than the D, +/- on the AutoStick. I want to pick up one of the standard shifters and see for myself what it looks like for the mechanicals. I need to make a trip to the dealer to find out if there are different listings for the standard CVT2, the CVT2L and the AutoStick for these parts: Shifter, TRS, cable and anything else that I can think of. If someone knows of some other mechanical piece that may affect the linage I'll add it to may list.
These transmissions are a lot more electronic than mechanical, at least on what controls them.
I even type out load a lot. Go for it.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #21 of 70 Old 01-26-2008, 09:48 AM Thread Starter
CharBroiled
Id like to know if the shifters have the same gate positions and throw too. if "L" is the same as "+/-" then I can use the stock shifter.. "L" would put it into +/- mode if I can trick the TCU into thinking theres a autostick shifter. then I can use any switches I want to shift.
what I was thinking of doing was this: use the wheel audio controls as paddle shifters and leave the stock shifter there. be able to go either paddles with no (or limited) wheel audio controls, or stock with normal shift and full audio controls.
Im sure I can do this with a PIC (PIC is a small computer about half the size of a deck or cards, programmable with lots of input output capability) I would insert the PIC in between the steering wheels CAN bus (think its CAN anyway) and the rest of the CAN bus so I can isolate it.
in BYPASS mode the pic would be invisible and just pass the data from the wheel to the rest of the system. everything would work stock. "L" would select "L" and wheel audio control work as normal.
in PADDLE mode the PIC would intercept any data from the left wheel control and send a DOWNSHIFT signal hardwired to the TCU, any right wheel audio control would send the UPSHIFT signal to the TCU. "L" would actually be the +/- position. I would lose some (or all, depends on how I program it) of the wheel audio controls while in PADDLE mode though.. small price
the PIC I was thinking of has 8 I/O ports.. 2 for the wheels CAN bus, 2 for the cars CAN bus, 1 for upshift signal, 1 for downshift signal, 1 for BYPASS/PADDLE and one for an UPSHIFT light (maybe, that upshift light would take a lot of programming)
only issue is switching back and forth.. I need to know exactly how to trigger a "see if I have autostick" easily.
and I would need to know how to ride the CAN bus so I can program the PIC. Im sure CAN protocols are floating around somewhere.
come to that, do the steering wheel audio control signals use the CAN bus?
post #22 of 70 Old 01-26-2008, 05:16 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Touche! Brain overload! I sure sounds like it would work. I'll need to track down some more wiring diagrams and see if they are what your looking for.
We'll find out some of that info with the "more simple" conversion and them progress from there.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #23 of 70 Old 01-26-2008, 05:28 PM Thread Starter
CharBroiled
basically I would need a wire diagram for the steering wheel and its electronics, especially its CAN connector. Ive been looking into CAN interface chips and there are more than you can shake a stick at.. and some are basically simple, small programmable computer chips with a CAN interface and I/O built in - perfect for what I want.
this could be fun
post #24 of 70 Old 01-30-2008, 07:26 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
We need some help on gathering some data on the CVT: mph (K/h) at 2500 rpm in L (or 1st w/AutoStick). Please include whether you have FWD, FD I or FD II and tire size.
Example:
2500rpm = 13mph. CVT, FD I, AutoStick in 1st gear, 29.1" tires. That's just an eyeball on the analog speedo. Correction for tire size is 13.39mph.
THANKS!
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #25 of 70 Old 01-30-2008, 04:20 PM Thread Starter
CharBroiled
this is a 07 patriot 4x4 FD I CVT2.
in "L" its 22-23 MPH at 2500 RPM.
thats with the stock Goodyear Wrangler SR/A 215/65-17 tires. not sure what the actual tire diameter is, and its raining out so I didnt check if you need that info lemme know.
hope this helps
post #26 of 70 Old 01-30-2008, 04:22 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
hope this helps
"Stock tire size" is plenty good enough! We just need to know if we need to correct for non stock tires. Thanks!
Anybody else? The more data the better!
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #27 of 70 Old 01-30-2008, 04:44 PM
Coasty161
2500rpm at 20mph in "L" FD1 29" tires 235/65/17
Coasty161 is offline
post #28 of 70 Old 01-30-2008, 04:47 PM Thread Starter
CharBroiled
edit: never mind, I just noticed you have different tires than I do.
post #29 of 70 Old 01-30-2008, 04:59 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Did you have your speedo recalibrated? If not, what were your stock tires?
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #30 of 70 Old 01-30-2008, 05:28 PM
Coasty161
no recal, stock tires are the 215/60/17
AutoStick - How Best To Use It ??? ChillyWillys Jeep Compass & Patriot Forum 12 05-21-2009 11:16 AM
Jeep Compass Fold Flat Conversion compass0018 Jeep Compass & Patriot Forum 3 04-22-2009 01:14 PM
2008 Compass, Autostick Trans, 4th gear Cobydick Jeep Compass & Patriot Forum 4 11-28-2008 06:09 PM
question for you autostick folks CharBroiled Jeep Compass & Patriot Forum 8 09-21-2008 01:17 AM
Front end conversion? phokur Jeep Compass & Patriot Forum 3 03-04-2008 07:56 PM
