Atf 4 leak from transmission. - JeepForum.com
post #1 of 3 Old 07-08-2013, 09:01 AM Thread Starter
rhdeese
2007 MK Patriot
Ok here it goes. I have read the pros and cons on the fluid type to use in the manual trans. I have replaced the seals three times and had it professionally done the fourth and continues to leak at front passenger side. Replace the drive shaft as well. I hate having fluid in my drive way.
I feel that if I drain the required fluid and replace it with a thicker medium the leak will stop.
My question is what is the forum suggestions?
My MK is an 07 fd1 with 80k. Thanks for any feedback.
rhdeese is offline
post #2 of 3 Old 07-08-2013, 09:08 AM
tjkj2002
2002 KJ Liberty
Sounds like the bearings(or bushings) in the trans is shot allowing to much axial play in that inner CV cup.Fix it correctly and it will stop the leak.
tjkj2002 is offline
post #3 of 3 Old 07-08-2013, 01:47 PM Thread Starter
rhdeese
2007 MK Patriot
Thks. I will look into that.
rhdeese is offline
