-   Jeep Compass & Patriot Forum (http://www.jeepforum.com/forum/f98/)
-   -   Atf 4 leak from transmission. (http://www.jeepforum.com/forum/f98/atf-4-leak-transmission-1546426/)
rhdeese 07-08-2013 10:01 AM
Ok here it goes. I have read the pros and cons on the fluid type to use in the manual trans. I have replaced the seals three times and had it professionally done the fourth and continues to leak at front passenger side. Replace the drive shaft as well. I hate having fluid in my drive way.
I feel that if I drain the required fluid and replace it with a thicker medium the leak will stop.
My question is what is the forum suggestions?
My MK is an 07 fd1 with 80k. Thanks for any feedback.
tjkj2002 07-08-2013 10:08 AM
Sounds like the bearings(or bushings) in the trans is shot allowing to much axial play in that inner CV cup.Fix it correctly and it will stop the leak.
rhdeese 07-08-2013 02:47 PM
Thks. I will look into that.
The time now is 01:20 AM.
