Antenna Mount (factory) - JeepForum.com
post #1 of 4 Old 06-14-2010, 06:48 PM Thread Starter
snood
snood's Avatar
2007 MK Compass
So I went to the car wash and my antenna broke up. First time I ever drove my car through one in three years, but with no hose at my place now it was long over due. I purchased a replacement one but the old one is rusted on so I wanted to see if anyone has a brake down on how to access the mount and possibly a part number.
'07 Compass -> I apologize to the next owner.
snood is offline
post #2 of 4 Old 06-15-2010, 07:09 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
It looks easier than I thought. It appears to plug into a harness as opposed to plugging directly into the radio, which would require pulling the center stack apart.
Fig A
1. Disconnect and isolate the battery negative cable.
2. Remove antenna mast by unscrewing mast from antenna body. On vehicles equipped with manual retractable antenna, lower antenna fully.
3. Remove shroud (1), if equipped.
4. Remove antenna nut (2) and adapter (3)
Fig B
5. Disconnect antenna body cable from instrument panel antenna cable.
6. Remove inner fender shield as necessary to gain access to mounting fasteners.
7. Remove antenna body and cable (2) assembly from fender (1)
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 4 Old 06-15-2010, 08:40 AM Thread Starter
snood
snood's Avatar
2007 MK Compass
Do you have a breakdown on how to remove the fender or is it self explanatory?
snood is offline
post #4 of 4 Old 06-15-2010, 09:53 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
The inner fender panel is held on by the plastic push pins and a few screws/bolts. Removing the wheel will let you get to all of them. On the larger push pins, pry out the center with a couple of small screwdrivers and then use a panel remover or similar tool to get all of the pin out.
FIG A
1. Remove the front fasteners (1).
FIG B
2. Remove the remaining 3 - 5 fasteners (1) and remove the splash shield (2)
Bob
posts 68 & 69
Also visit me at
Gramps is offline
antenna mount , antenna replacement , compass , instructions , patriot
Uconnect For A Factory No Factory Install 229bonehead Jeep Compass & Patriot Forum 1 08-10-2008 10:46 PM
Stubby or Bullet antenna?? rob_rector Jeep Compass & Patriot Forum 23 06-30-2008 06:34 PM
Anyone try this? (Aftermarket antenna) Jgrillz Jeep Compass & Patriot Forum 4 05-28-2008 09:16 PM
Sirius Antenna Installation on a Compass tryinginvain Jeep Compass & Patriot Forum 4 05-27-2008 07:13 PM
Antenna Questions tabcounter Jeep Compass & Patriot Forum 2 03-04-2007 05:40 PM
