Air noise with rear windows down 09 patriot - JeepForum.com
post #1 of 8 Old 05-23-2010, 03:19 PM Thread Starter
ratman91
2009 MK Patriot
I just bought an '09 patriot and my daughter decided to roll down the back window on the freeway and the air comming in created a pounding in my ear. The noise was like changing pressure in the jeep about twice a second. if I roll down a front window the sound goes away. The noise only happens above 40 MPH and only with one or both rear windows fully down. Has anyone else noticed this problem? Could use some sugestions on what causes this.
Thanks
ratman91 is offline
post #2 of 8 Old 05-24-2010, 04:59 PM
howdy246
2008 MK Compass
yep.. almost all compass's do that.. not sure why. If you want a real eye popping experience leave both front windows up and both back windows down..now hit about 100km.. You feel like your head is going to explode!
howdy246 is offline
post #3 of 8 Old 05-24-2010, 06:08 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Almost all SUV's and station wagons do that including the Chevy HHR.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #4 of 8 Old 05-25-2010, 08:09 PM
Dacaur
Dacaur's Avatar
2008 MK Patriot
Every SUV and most cars I have ever owned and or ridden in do that when you have only rear windows down. Its due to the air rushing past the open rear window, rather than into it, which creates a negative pressure inside the vehicle. (think about how a big rig creates a suctions behind it, which small cars use to save gas, same concept) Atmospheric pressure rushes in to equalize the pressure, once the pressure is equalized, the air still rushing past creates a negative pressure inside the vehicle... and the cycle repeats.. rolling down a front window stops it happening, since when the front windows are down air flows into the jeep, preventing the negative pressure from occurring.
As for the sound, The way speakers create sound is by vibrating a membrane, which moves air back and forth, well, think of your jeep as very large subwoofer... you get the picture...
The reason it only happens with the BACK windows is due to aerodynamics... The front windows dont have a flat area in front of them like the rear ones do (That flat area being the front window), and when you open a front window, air rushes IN the window, rather than PAST the window like in the rear...
Dacaur
99 WJ Laredo
2.5" Budget boost, 265/75/16 tires, K&N air filter
Past Jeeps:
1992 YJ 4.0, 5 speed 6", lift 33's
1992 XJ 4.0, auto, 3" lift, 31's
1999 XJ 4.0, auto, 3" lift, 31's
1985 XJ 2.5, 5 speed, no lift, 255/70/15's
Dacaur is offline
post #5 of 8 Old 05-30-2010, 10:53 AM
deepnite10
THUMP, THUMP, THUMP..
at first i thought it was the tires..
then i found that cracking the front windows eliminates
the thumping..*somewhat*
deepnite10 is offline
post #6 of 8 Old 09-01-2014, 05:39 AM
KathrynCoe
Yes!
I have a 2014 Jeep Patriot and had the rear windows partially open while driving. There was a horrible whump whump whump sound and I felt like I was going to pass out. Afterwards, my ears were blocked similar to what happens on an airplane. It was very strange and scary.
KathrynCoe is offline
post #7 of 8 Old 09-01-2014, 08:22 AM
BostonStrong
2013 MK Patriot
Dacaur is right. Every SUV I've had has done this. It's a pain when friends roll the windows down in the back!
BostonStrong is offline
post #8 of 8 Old 09-01-2014, 01:19 PM
miscrap
miscrap is offline
compass , patriot , rear windows , wind noise
Tranny noise, 08 patriot RollingOn33s Jeep Compass & Patriot Forum 5 02-23-2009 05:49 PM
Windows in '09 Patriot: slow, stuck, frozen, etc tripleGmax Jeep Compass & Patriot Forum 9 01-23-2009 03:40 PM
Dashboard creaking noise on Patriot? mich99TJ Jeep Compass & Patriot Forum 0 04-06-2008 01:10 PM
Jeep Patriot w/foggy windows!! emo Jeep Compass & Patriot Forum 11 12-20-2007 05:22 PM
Patriot engine noise danbo Jeep Compass & Patriot Forum 10 06-12-2007 07:55 PM
