Aftermarket Struts/Shocks - JeepForum.com
post #1 of 4 Old 08-22-2012, 09:19 AM Thread Starter
bigkat91
2011 MK Compass
I wonder when the aftermarket suppliers like Bilstein,Monroe,..etc. Don't have replacement struts available for Compass and 'Riot? It would be nice when installing either the RRO kit or the Aussie coils to have the options of upgrading the struts too..
2011 Compass 120K miles
RRO Lift
bigkat91 is offline
post #2 of 4 Old 08-23-2012, 07:24 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
These show for 2007 - 2010. You may be able to find out from the dealer if the 2011/12 are the same part numbers as the earlier ones.
Monroe (& NAPA) show the OEM replacements
Front Left 72368
Front Right 72367
Rear 72401
and a mounting kit, 906969 that includes: MonroeŽ Strut-MateŽ mounting kits* include: Strut Mount, Bearing, Upper Spring Isolator, Lower Spring Isolator, or Upper Spring Seat.
You may be able to cross reference to others.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 4 Old 08-23-2012, 09:13 AM Thread Starter
bigkat91
2011 MK Compass
I did do some more searching last night and found out that KYB makes them for the 2007-2010 years as well. Will look further into the cross referencing. Thanks for the Monroe numbers!
RRO Lift
bigkat91 is offline
post #4 of 4 Old 08-23-2012, 02:45 PM
festerw
festerw's Avatar
FWIW when I replaced mine the dealer actually had better prices than the parts stores.
Hers - 2011 Dodge Durango Crew
Mine - 2003 Jeep Wrangler X
1998 Jeep Cherokee Classic
festerw is offline
Has anyone upgraded your struts? case5412 Jeep Compass & Patriot Forum 4 05-11-2011 04:40 PM
Bad Tie rod..struts leaking Elihawk Jeep Compass & Patriot Forum 10 05-03-2011 04:21 PM
New Struts/ Control Arm wesleyd Jeep Compass & Patriot Forum 1 02-10-2010 01:52 PM
Aftermarket radio LuZ Jeep Compass & Patriot Forum 13 08-05-2008 06:26 PM
Anyone try this? (Aftermarket antenna) Jgrillz Jeep Compass & Patriot Forum 4 05-28-2008 08:16 PM
