Aftermarket Radio Installation Guide (beta)
| Official Chassis Saver Rust Preventive Truck & Auto Un | TJ 5.25" Speaker Adapters - NalinMFG | SALE -- Yukon Gear Free Spin Hub Conversion Kit - Dana 30 |
#16 | |
Maybe this will help. It's the PDF that reflects the installation of the Mopar IPOD Kit, but it gives a nice display on removing facia panels and the stock heads. The PDF includes several models, so scroll down to the Compass/Patriot section.
http://site.justforjeeps.com/guide/82209617.pdf
#17 |
^ That PDF is very helpful. If anyone else has something similar with written instructions it would be great. I'm planning on replacing my factory basic stereo this week and the combination of that PDF plus the instructions in this post are very helpful but I'm very very new at this type of thing so if someone has a link to a walkthrough for idiots that would be awesome. Thanks!
As far as I understand it I'll just have to get the radio out (the hard part) and then use the supplied harness I get with the aftermarket radio and crimp some wires to make it work. Also, can someone with an aftermarket radio installed please verify what harness you used and verify what functionality you lost or didn't lose? From reading this thread it looks like the deck won't be illuminated but that's the only thing lost? I just want to be absolutely sure of everything I do before I go to work on my brand new Jeep. Hope I'm not being a pain, thanks! edit On second thought, after staring at that PDF for a while I think I should be just find if I can find the right tool. I guess I really just need confirmation for the second and third paragraphs of my original post. Last edited by websurrfr; 07-07-2007 at 06:57 PM.. |
#18 |
The Necessary Evil
![]() Join Date: Aug 2006
I don't believe that it's necessary to remove the "A" Pillar Covers, Front Trim Panel or the Glove Compartment to get the radio out. That is only for running the wires for the Ipod. Figure 3 shows about all that needs to be rmoved.
Bob Artificial intelligence is no substitute for natural stupidity MK Skid Plate fasteners for sale posts 68 & 69 Also visit me at Photobucket '06 WK Grand Cherokee Limited Quadra-Drive II, 5.7 '07 MK Compass Limited 4X4, AutoStick |
#19 |
I have replaced my factory head unit with a Pioneer DEH-P3900MP. It works perfectly. I have lost ZERO functionality. I used the standard cheap harness that Crutchfield supplied. I did not need a CANBUS harness to retain any functionality. Thank you all for your help.
#20 | |
The Necessary Evil
Pic 1 - Top cover Pic 2 - clip Pic 3 - HVAC trim Pic 4 - HVAC connectors Pic 5 - Radio Your own from there. It should be pretty easy. Putting everything back together is also very easy.
#21 |
The Necessary Evil
A couple more pictures.
The CVT shift Knob just pulls off by pulling up on it. The trim ring comes out easily by using a panel tool. Then there are 2 screws that hold the shifter bezel in place.
#22 |
if you dont have any special tools to remove it, what can I use then? or should I just go to my dealer to do it?
#23 |
The Necessary Evil
Your "location" says EU so I'll take that you are in Europe and I'm not sure of your supply houses over there. The most handy that I've used so far are the 3rd and 4th from the left. You should be able to find something at a household/kitchen supply store that you can use to make one. Plastic is preferred so that you don't scratch the parts that you are working on, about 6mm (1/4") thick tapering down to almost nothing over about 25mm (1"). Just looking around my garage I found a plastic handled brush that I could cut down nicely and make it work. Just about any sturdy plastic handled spatula may do the trick, too. You're just trying to wedge something between the parts and pry them apart. On the top cover, start on the sides closest to you and work towards the windshield. Lift up on the rear of it and slide it towards you to pull it out. There are no clips in the front where the "tang" is located.
#24 |
actually im in the USA now. I stopped by Autozone, but they didn't have anything like that.
Would a large putty knife work? |
#25 |
The Necessary Evil
It may but, something wedged shaped would be better and a putty knife may be too flexible. A gasket scraper would be better but it is metal so be careful. I got mine from Harbor Freight online, the local store didn't have them. A paint and auto body supply store should have them. Are you here for a while or for good? Where abouts?
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?function=Search
#26 |
Now I'm in chicagoland area (from Joliet actually) but I spend about 9-10months/year in Poland. I bought a compass here and am fixing it up with a car computer.
I bought a replacement front bezel for the NAV system which fits my 7" touchscreen fine, and I just need to mount it and power it. Its powered with + Battery, - Batery and + ignition. after I get it all done, ill ship it out to Poland. (and it is cheaper than buying there as a limited compass is over 60K USD and shipping is 1-1.6K USD) I'm actually only here for about a week and trying to finish this build. |
#27 | |
If you get any time when done, could you post pics and/or install equipment. I have been researching CarPCs for awhile and pretty much have most of the computer parts laying around except for the touch screen. Thanks a bunch, Jim ps.. I was born and raised for 14 years in Ottawa, IL. Not far from Joliet.
[URL="http://www.nearlynormal.biz/jeep/patriot_info.html"][B][FONT="Fixedsys"][SIZE="4"][COLOR="DarkOliveGreen"]Home Grown Patriot Info Site[/COLOR][/SIZE][/FONT][/B][/URL] |
#28 |
Sure!
I went to the jeep dealer and he had no problem unsnapping it. It was more force needed than I thought ( I was afraid I would break it) |
#29 | |
I'd like to see how to get this in my Durango. Thanks
Flame Red Rubicon Unlimited Auto, Power, Dual Tops, Tow, Tint BA 12/19/06, D 01/08/07, D1 02/14/07, G 03/07/07, KZL 03/08/07 DELIVERED 03/15/07 !!!!! |
#30 |
instal radio 09 patriot ?
| Tags |
| compass, guide, head unit, install, patriot, radio, remove |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
