Quantcast Aftermarket radio - JeepForum.com
Go Back JeepForum.com > Models > Compass & Patriot Forum > Aftermarket radio
RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comPoison Spyder Brawler Rockers!TJ WW2WW rockers on sale with free gaskets this month.
Old 07-22-2008, 12:07 PM   #1
LuZ
2008 MK Patriot
Aftermarket radio
Hi...
i want to change the radio into my Patriot 2008...
I heard that the wire harness works for the sound but the power is in another wire harness. (Is why the radio closes only when we open the doors)...
So someone got guide to help me for the installation ???
I know how to remove the radio, i only want to know how to plug the other radio into !
Thanks
LuZ is offline   Reply With Quote
Old 07-22-2008, 08:10 PM   #2
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
You will need a CanBus adapter for whichever radio that you get. What are you getting and from whom? Crutchfield has some kits that I've heard will work, maybe some others, too.
Bob
MK Skid Plate fasteners for sale posts 68 & 69
Also visit me at Photobucket
Gramps is offline   Reply With Quote
Old 07-22-2008, 08:33 PM   #3
LuZ
2008 MK Patriot
CanBus adapter
But CanBus is not only if a got the factory amplifier ?
cause i don't have it !
Old 07-22-2008, 08:51 PM   #4
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Even the basic radio uses the CanBus system, it's got to do with the Intergrated Power Module and all of the electronics. I'll try and dig up some threads to link to tomorrow.
Bob
Old 07-23-2008, 07:44 PM   #5
LuZ
2008 MK Patriot
Aftermarket radio
Ok...
so if i understand....
i need to buy the CANBus adapter like Scosche DCCR03SR (80 to 120$) ?
Old 07-23-2008, 09:08 PM   #6
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Yes, that is typical of what you need to replcae the factory unit with an aftermarket one. If you wanted to go with a nicer factory unit that you can find on ebay then you wouldn't need that.
http://www.carstereomall.com/car-stereo-products/scosche-dccr03sr.htm
Bob
Old 07-27-2008, 08:34 PM   #7
Laloggia
You are correct in needing to run the red wire to an ignition power source. I went to Circuit city and bought the standard Jeep wire harness (the installer knew which one) for like $29.99. He was very helpful and stated i needed to do this. I ran mine (the red wire from this plug in harness) to the cig lighter power wire and it works perfectly. Radio goes off when the door opens. Its this simple. No need having to get any additional adapters. You will also probably need an antenna adapter.
2005 Wrangler Impact Orange
2005 Chrysler Crossfire
2006 Jeep Commander
Laloggia is offline   Reply With Quote
Old 07-28-2008, 07:30 AM   #8
LuZ
2008 MK Patriot
aftermarket radio
Ok but... if i do that....
The radio button on my steering will not work !!!???
Old 07-29-2008, 07:27 PM   #9
Laloggia
ok....your right. I do not have the steering wheel controls. You will need a separate piece for that if its available.
2006 Jeep Commander
Old 08-01-2008, 10:15 PM   #10
LuZ
2008 MK Patriot
Aftermarket radio
If i want to use the power (12V) from the cig. lighter...
did i need to unplugged it or a can only start a new wire from the cig lighter to my radio ?
thanks
Old 08-04-2008, 07:04 PM   #11
Laloggia
You can start a new wire from the +positive wire on the cig lighter wires. Splice it in and run it up behind the dash to your radio. Thats it. I have had no problems....thought i might blow a fuse at first because of the power draw, but that never happened. Also have the XM power source tapped in there too. Beats trying to fish a wire through the firewall.
2006 Jeep Commander
Old 08-04-2008, 07:32 PM   #12
LuZ
2008 MK Patriot
Aftermarket radio
Did we need to ground the radio ?
Old 08-05-2008, 04:36 PM   #13
Laloggia
There should be a ground wire in the new harness adaptor u get. You should not have to run a separate ground.
2006 Jeep Commander
Old 08-05-2008, 07:26 PM   #14
LuZ
2008 MK Patriot
aftermarket radio
Ok...
thanks a lot dude for your help !
Glock Forum
