Adding a New 12V Plug - JeepForum.com
post #1 of 4 Old 12-09-2012, 07:28 AM Thread Starter
zstatman
2013 MK Compass
Mine only has 1 and its activity is controlled by the key being off or on. I would like to install another one that is always hot. Must I run new wires from the battery to the plug or is there another access port, so to speak, where can run always hot wires to the plug?
Tks
2015 Compass Latitude 4x4
"Of all the paths you take in life, make sure a few of them are dirt"
zstatman is offline
post #2 of 4 Old 12-09-2012, 07:42 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
This isn't quite the answer you want but it's a start. http://www.jeepforum.com/forum/f98/a...-area-1208883/
I would run it as a separate fused lead straight from the battery. The TIPM is a fussy creature and doesn't like add ons so tapping off of something else could be a problem.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 4 Old 12-09-2012, 12:25 PM
dahozzman
2010 MK Compass
Tks
Honestly, your best bet is to run a fresh wire directly from where the battery feed connects to the main fuse box under the hood. An alternative would be to locate a constant hot wire under the dash that feeds, for instance, the interior lights and tap into that.
Use a test meter to confirm, but the wire color code I suggest you look for (reference Jeep Factory Service Manual) is either PK/GY that runs from the ignition switch or RD/DG that runs from the battery itself. The main harness runs behind the drivers side kick panel. Lots of kits for this kind of thing can be found on EBay searching for "12V Outlet".
Either way, be sure and add an inline fuse.
Cheers
2010 Compass LTD Added UConnect w/IPhone cable, front/rear MOPAR mud flaps, K&N drop in air filter, hardmount gooseneck cell phone station, MOPAR cargo liner, MOPAR cargo net, remote Radar Detector w/Voltmeter readout, upgraded speakers/added Tweeters & sub-woofer, MOPAR Back-up Camera/monitor, front lower grill, interior wood accents
dahozzman is offline
post #4 of 4 Old 12-10-2012, 06:31 AM Thread Starter
zstatman
2013 MK Compass
Thanks much for the info
zstatman is offline
12v power outlet
