-   Jeep Compass & Patriot Forum (http://www.jeepforum.com/forum/f98/)
-   -   Adding a New 12V Plug (http://www.jeepforum.com/forum/f98/adding-new-12v-plug-1447876/)
zstatman 12-09-2012 08:28 AM
Mine only has 1 and its activity is controlled by the key being off or on. I would like to install another one that is always hot. Must I run new wires from the battery to the plug or is there another access port, so to speak, where can run always hot wires to the plug?
Tks
Gramps 12-09-2012 08:42 AM
This isn't quite the answer you want but it's a start. http://www.jeepforum.com/forum/f98/a...-area-1208883/
I would run it as a separate fused lead straight from the battery. The TIPM is a fussy creature and doesn't like add ons so tapping off of something else could be a problem.
dahozzman 12-09-2012 01:25 PM
Tks
Honestly, your best bet is to run a fresh wire directly from where the battery feed connects to the main fuse box under the hood. An alternative would be to locate a constant hot wire under the dash that feeds, for instance, the interior lights and tap into that.
Use a test meter to confirm, but the wire color code I suggest you look for (reference Jeep Factory Service Manual) is either PK/GY that runs from the ignition switch or RD/DG that runs from the battery itself. The main harness runs behind the drivers side kick panel. Lots of kits for this kind of thing can be found on EBay searching for "12V Outlet".
Either way, be sure and add an inline fuse.
Cheers:cheers2:
zstatman 12-10-2012 07:31 AM
Thanks much for the info
The time now is 05:34 AM.
