2wd vs 4wd compass - JeepForum.com
post #1 of 10 Old 01-03-2013, 04:58 PM Thread Starter
tomhale114
2wd vs 4wd compass
I've got a 2007 2wd compass but I want to be able to take it muddin a little bit. Nothing too crazy though. Since it's a 2wd what can I do to be able to keep up with the 4wds as best as possible?
tomhale114 is offline
post #2 of 10 Old 01-03-2013, 06:50 PM
NHPATRIOT
2014 KL Cherokee
You will be sorry trying to go mudding with a 2WD. Mild off roading ok but mudding? If you want to go mudding and keep up with the 4WD's go buy a 4WD.
Not even much you can do tire wise to help.
Not meant offensive.
2014 Jeep Cherokee
Latitude
3.2L Pentastar V6
Active Drive I
NHPATRIOT is offline
post #3 of 10 Old 01-03-2013, 06:57 PM
Masta-P
a winch.
Masta-P is offline
post #4 of 10 Old 01-03-2013, 07:01 PM
ItsJustD
Mud tires + locker? Or a Winch lol..... Best bet is to sell it and buy a 4wd....
ItsJustD is offline
post #5 of 10 Old 01-04-2013, 12:28 AM
aroundincircles
1989 XJ Cherokee
No lockers available for a patriot FDII has BLD, but not available on the 2wd... Get really good mud terrain tires, or ATs. Turn of Traction control. its a bit aggressive on the patriot/compass and will stop you cold. and get a tow strap, and make sure you have tow hooks and somebody to pull you out...
aroundincircles is offline
post #6 of 10 Old 01-04-2013, 12:40 AM Thread Starter
tomhale114
Lol thanks! Would I still be getting stuck allot even if the mud isn't that severe? & would getting a lift kit help?
post #7 of 10 Old 01-04-2013, 12:46 AM
ramthis426
2005 WK
Find a cheap xj
05 3.7 wk QT1,2.25 Old Man EMU,255/75/17 GY silent armors,call of duty black moabs,Spidertrax
1.5,Pinch weld & rear fender mod,hypertech max energy.1992 jeep xj larado 4.0,4.5 rought country lift, coustome built rear bumper with tire swing soon to be on 33s
ramthis426 is offline
post #8 of 10 Old 01-04-2013, 12:48 AM
ramthis426
2005 WK
Yes your still be getting stuck a lot idk a lot about your jeep but im willing to bet its an open dif that would be like trying to take my mustang muddying won't work to well lol
post #9 of 10 Old 01-04-2013, 02:33 AM
aroundincircles
1989 XJ Cherokee
in this case no, A lift kit helps with ground clerence, not traction. Your best bet is good tires. It all depends on the mud... No idea, with out being there, what it would look like. FWD actually gets pretty good traction over a RWD car, as the weight of the engine sits on the drive tires. That's why for snow you get best traction from 4wd/awd, then from fwd, and far behind rwd. but depending on how sticky and deep the mud is, it could be too much weight.
Again:
1)Get really GOOD tires
2)Turn off Traction control while you're out in the mud. The TC is very aggressive, and will stop you cold when you least expect it.
3)Bring a tow rope and make sure you have at least one tow point on your car, Like a hitch.
Do you have 16" or 17" rims? a very popular off road tire is the yokohama geolander AT/S. you can get them in stock, or very close to stock sizes (so you don't have to worry about rubbing or clearance) I have a FDII, so I'm running 245/65-17 Falken Rocky Mountains and Love them.
You're not going alone, which is the most important part, even if you get stuck, somebody can pull you out (if you have the above)
post #10 of 10 Old 01-04-2013, 05:13 PM Thread Starter
tomhale114
Thanks that helps allot!
