2015 patriot high altitud: no trailer hitch?? - JeepForum.com
post #1 of 5 Old 03-09-2015, 07:24 PM Thread Starter
nothingface
I was planning on getting a bike rack and possibly a trailer to pull. Why is there no hitch on this jeep? Is it because it's only 4 cylinder and not strong enough? Has anyone put a hitch on? Thanks
nothingface is offline
post #2 of 5 Old 03-10-2015, 10:18 AM
JerryGNYC
2015 MK Patriot
There's no hitch because you didn't order the vehicle that way. I was looking for a Pat with the towing prep package, but there were none available in my area, and I didn't feel like ordering and waiting... :P
IIRC, towing capacity is in the manual. And FWIW, Curt makes some nice bolt-on receivers for the Patriot and Compass (and others...).
- Common sense is on perpetual backorder.
JerryGNYC is offline
post #3 of 5 Old 03-11-2015, 01:51 PM
caulk04
2008 WK
Without the factory trailer prep group, you're only rated for 1000lb towing. The tow group includes an aux engine oil cooler and then you're rated for 2000lb. IMO, you're fine at 2000lb anyway, just don't be running the 'Ike Gauntlet' or anything crazy.
But yeah, there's no hitch because you didn't buy one.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #4 of 5 Old 03-13-2015, 10:39 AM
Hondatrix
Originally Posted by caulk04
Without the factory trailer prep group, you're only rated for 1000lb towing. The tow group includes an aux engine oil cooler and then you're rated for 2000lb. IMO, you're fine at 2000lb anyway, just don't be running the 'Ike Gauntlet' or anything crazy. But yeah, there's no hitch because you didn't buy one.
transmission cooler on auto..
Hondatrix is offline
post #5 of 5 Old 04-26-2015, 08:11 AM
goodwin_7
I purchased a diy towing kit from tractor supply in NC and mount everything to my jeep patriot. I was able to pull a little over 1800 pounds in a U haul trailer from NC to AZ. Took it a second to get up and go but those four cylinders worked like a champ. I am actually doing the same trip back to NC in a few weeks.
goodwin_7 is offline
