2012 Compass 5 Spd Shift Knob removal - JeepForum.com
post #1 of 11 Old 07-17-2012, 04:38 PM Thread Starter
RCAF_JP
2012 MK Compass
I am brand new to the site, and have been trying to search the net all day to find a way to remove the stock 5 speed shift knob from my compass.
I can get the boot off it, and the top chrome cap, but as for the knob itself: its not budging.
I want to be able to replace it as it is just not the right feel for me. Makes shifting awkward.
Any help would be appreciated, as pulling it, twisting it, and searching it for retention screws has had no results.
That thing is stuck on there good.
RCAF_JP is offline
post #2 of 11 Old 07-18-2012, 10:22 AM Thread Starter
RCAF_JP
2012 MK Compass
OK so UPDATE: talked to my dealerships service dept, and according to their shop manuals: "if the shift knob on the 2011+ 5 speed is damaged, the entire shifter assembly must be replaced, as the shift knob is not designed to be removed."
Good to know, but it seems kinda foolish to me that they would design it like this.
RCAF_JP is offline
post #3 of 11 Old 07-18-2012, 12:55 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
That really sucks but at least you found your answer. I do wonder if an earlier assembly could be used and then replace the knob on that. Wrecking yard item?
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #4 of 11 Old 07-18-2012, 04:52 PM
FujativeOCR
2011 MK Patriot
They really do everything they can think of to prevent us from customizing our cars don't they. I wonder why?
FujativeOCR is offline
post #5 of 11 Old 07-19-2012, 05:35 AM
ddavidv
2008 MK Patriot
On the Patriot site I've read of people just taking a saw to the thing and cutting it off. You're committed to replacing the knob then, but that is the ultimate goal anyway. I agree, the feel of the stock knob is terrible.
ddavidv is offline
post #6 of 11 Old 07-19-2012, 12:40 PM Thread Starter
RCAF_JP
2012 MK Compass
It just doesn't sit right in the hand. I'm hesitant to take a saw to it, because if its non removable, the odds that the shifter arm is threaded are slim.
RCAF_JP is offline
post #7 of 11 Old 07-21-2012, 06:51 AM
ddavidv
2008 MK Patriot
The shift lever is NOT threaded. The knob is a press fit.
ddavidv is offline
post #8 of 11 Old 07-22-2012, 09:02 AM
cuemark8
2007 MK Compass
shift knob replacement
I'm not familiar with the new design of the Compass shift knob and linkage, but in the older version the shift knob simply was pressed onto the shaft. By pulling upward it would slide off. It was not threaded!
If the new version is not removable cut it off. I cut my shaft down some anyways to shorten the throw.
Must new shifter knobs are made for a univesal fit. Mine was a MOMO shift knob. It has a base collar that has a rubber bushing to provide and expanable but snug fit. It slides over the shaft first and then the knob is set on the shaft it has 3 set screws that tightly hold the knob on the shaft. The shift knob tapers at the base where it has a threaded base. The base collar slides back up the shaft and threads onto the shift knob. This collar/bezel ,whatever you want to call it, hides the set screws and provides a flawless finish. As far as I know most shift knobs are made this way.
Cutting the shifter shaft may prove tricky. It is made of hardened steel made not bend or break. It is really hard to cut with any saw. I used a canvas blanket to protect the interior and used a grinder to cut it off.
cuemark8 is offline
post #9 of 11 Old 07-26-2012, 09:58 PM Thread Starter
RCAF_JP
2012 MK Compass
I would love to get the thing off, but it is on there bloody good. i even opened my sunroof and stood with one leg on each side of the console to pull upwards.
Im not exactly a little guy, but im guessing if that didnt work, I'll have to saw.
Theres got to be a better way though way, since MOPAR sells aftermarket shift knobs for the 2012 compass....
RCAF_JP is offline
post #10 of 11 Old 07-27-2012, 08:43 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
It sound like it may be easier to drill down through the plastic (assumed) shift knob and cut it off that way instead of cutting the shaft. Just thinking out loud again.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #11 of 11 Old 07-31-2012, 02:12 PM Thread Starter
RCAF_JP
2012 MK Compass
Yeah, in the end I had to dremel the damn thing off. but it looks better with the new shift knob. Pics to follow once my wife gets home with my camera.
RCAF_JP is offline
My parents want a 2012 compass. How are they? MacK Jeep Compass & Patriot Forum 26 04-22-2012 07:07 AM
2012 Compass/Patriot changes IRSmart Jeep Compass & Patriot Forum 0 06-06-2011 03:31 PM
Billet Shift Knob b1llyw Jeep Compass & Patriot Forum 0 03-14-2010 04:26 AM
Five Speed Shift Knob eze07mayhem Jeep Compass & Patriot Forum 4 06-08-2009 01:06 AM
'Cool Compass Shift Knob' youwannaknow Jeep Compass & Patriot Forum 36 01-03-2008 06:01 PM
