2011 Patriot 2.4L oil change - JeepForum.com
post #1 of 6 Old 09-09-2012, 11:24 AM Thread Starter
dnuccio
Just thought I would post this as kind of a how to. Doing the oil change is SOO MUCH easier if you take off the plastic "skid plate" underneath the engine. Taking it off gives you a ton more room to work, you dont have to worry about oil sitting on top of the skid plate and collecting dirt, and you can actually get a wrench on the oil filter. It removes with (6) 10mm bolts, 3 front and 3 back, and there are 4 body clips total, 2 in each wheel well, kind of behind the brake caliper and towards the front of the car. Hope this helps someone out
dnuccio is offline
post #2 of 6 Old 09-09-2012, 11:27 AM
FujativeOCR
2011 MK Patriot
That skid plate is only on the off-road packaged Patriots I believe.
FujativeOCR is offline
post #3 of 6 Old 09-09-2012, 12:50 PM
jasonwe
2012 MK Compass
The new Compasses have that plastic skid plate as well. My wife's is not the off-road package/trail rated, and it has it. I believe its called a splash guard or something along those lines.
2012 Jeep Compass Sport 4x4
2.4L I4, CVT II, Freedom Drive I
2010 Dodge Dakota Quad Cab 4x4
4.7L V8, 545RFE, Big Horn Edition
jasonwe is offline
post #4 of 6 Old 09-09-2012, 01:26 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Some of the earlier Compass' had only the side shields (like mine) and some had the full shield. So it's a non issue on some and of course the metal skid plates on the FD II are a non issue too. But thanks for offering the tip to those that can use it.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #5 of 6 Old 09-09-2012, 02:08 PM
bigkat91
2011 MK Compass
Mine has a hole in the plastic splash guard for access to the oil filter and a hole to access the drain plug.
2011 Compass 120K miles
RRO Lift
bigkat91 is offline
post #6 of 6 Old 09-10-2012, 11:06 AM
pitrcer3
2011 MK Patriot
Yea I have a 2011 2.4L Sport and it has the full skid plate. The first oil change I went to do myself I popped out all the 10mm bolts and then realize the 4 inside the fender's and figured it was just a stupid hassle to do that everytime to change the oil. The cut outs in the skid plate for the drain plug and oil filter are plenty. I can easily reach everything without even jacking up the Jeep and have the oil change in 15 minutes. I do agree though that I get some oil dripped on it and it will collect some dirt. I plan to drop the whole skid plate off this fall and scrub it off good.
pitrcer3 is offline
CAI for 2011 Patriot srtdodge05 Jeep Compass & Patriot Forum 3 07-21-2011 09:08 AM
New 2011 Patriot owner Wiskow Jeep Compass & Patriot Forum 8 06-14-2011 08:15 PM
2011 Compass vs. 2011 Patriot PirateSHU1 Jeep Compass & Patriot Forum 14 05-05-2011 10:20 AM
RBZ Radio in 2011 Patriot gazzie4 Jeep Compass & Patriot Forum 13 02-18-2011 10:04 AM
New 2011 Patriot RichN Jeep Compass & Patriot Forum 7 12-10-2010 08:37 PM
