2010 patriot not shifting well - JeepForum.com
post #1 of 9 Old 01-08-2013, 07:53 PM Thread Starter
JohnHancock
So I drove down south today about 3 hours and on my way back when I pull up to a light the engine has a hard time shifting into 2nd,3rd etc. is there a way to check the trans fluid? I think it might be low
JohnHancock is offline
post #2 of 9 Old 01-08-2013, 08:56 PM
FujativeOCR
2011 MK Patriot
Manual transmission?
FujativeOCR is offline
post #3 of 9 Old 01-08-2013, 09:33 PM Thread Starter
JohnHancock
No it's automatic but we need to refill the trans fluid except it says the dealer needs to do it. Can I fill the fluid without taking it to the dealer?
post #4 of 9 Old 01-08-2013, 10:26 PM
tjkj2002
2002 KJ Liberty
You have a CVT trans,requires dealer only fluid and yes it is expensive.
tjkj2002 is offline
post #5 of 9 Old 01-08-2013, 10:32 PM Thread Starter
JohnHancock
Any idea what I'm looking at paying to refill the trans fluid? Can I buy the fluid online and just top off my fluid?
post #6 of 9 Old 01-08-2013, 10:49 PM
FujativeOCR
2011 MK Patriot
Cvt...but sticks between 2nd and 3rd?? :-/
post #7 of 9 Old 01-08-2013, 10:57 PM Thread Starter
JohnHancock
No doesn't stick I just need cvt fluid because it is low. Is there any way I can buy some online and fill it a little?
post #8 of 9 Old 01-09-2013, 10:05 PM
PC12driver
2013 MK Patriot
Why would you think it's low on transmission fluid when there is no provision to check the level. A CVT transmission dosn't "shift" anyway, it varies the gear ratio on a smooth continual basis in response to load, speed etc. If it's not doing it's job right and feels "weird" or something it is probably time for a trip to the dealer to have it checked. If your lucky it might just be low on fluid but to monkey around and try and add some when that might not be the problem might do more harm than good and still not fix the problem.
Just my 2 cents worth....
PC12driver is offline
post #9 of 9 Old 01-09-2013, 11:05 PM Thread Starter
JohnHancock
We took it to a local mech who had the tool to check it. Plus he put some more cvt fluid in and it's running great now
