2010 jeep patriot trans fluid - JeepForum.com
post #1 of 8 Old 01-08-2013, 08:44 PM Thread Starter
JohnHancock
I have an automatic jeep patriot that needs trans fluid. I don't have $ to spend on taking it to jeep but it needs fluid bad. Can I put some ATF+4 in it to temp fix it?
JohnHancock is offline
post #2 of 8 Old 01-08-2013, 09:27 PM
tjkj2002
2002 KJ Liberty
If you put ATF+4,or any other ATF, in that is a sure bet that you will be buying a new trans.You need CVT fluid from the dealership.
tjkj2002 is offline
post #3 of 8 Old 01-08-2013, 09:31 PM Thread Starter
JohnHancock
Ok that's what I wanted to know. So it needs cvtf+4
post #4 of 8 Old 01-10-2013, 07:09 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
How did you determine that you needed trans fluid?
JeepCares is online now
post #5 of 8 Old 01-10-2013, 11:06 AM Thread Starter
JohnHancock
A local mech had the measuring tool from the dealer. He checked it and put like half a quart of cvt. which fixed the problems
post #6 of 8 Old 01-10-2013, 08:08 PM
tjkj2002
2002 KJ Liberty
So you going to fix the leak? The fluid just does not disappear.
tjkj2002 is offline
post #7 of 8 Old 01-10-2013, 09:13 PM
FujativeOCR
2011 MK Patriot
And was there any burned fluid inside it? Some signs of early cvt failure might be burned fluid.
FujativeOCR is offline
post #8 of 8 Old 01-10-2013, 09:36 PM Thread Starter
JohnHancock
Ill have to check for leaks.
