-   Jeep Compass & Patriot Forum (http://www.jeepforum.com/forum/f98/)
-   -   2010 jeep patriot trans fluid (http://www.jeepforum.com/forum/f98/2010-jeep-patriot-trans-fluid-1461038/)
JohnHancock 01-08-2013 08:44 PM
I have an automatic jeep patriot that needs trans fluid. I don't have $ to spend on taking it to jeep but it needs fluid bad. Can I put some ATF+4 in it to temp fix it?
tjkj2002 01-08-2013 09:27 PM
If you put ATF+4,or any other ATF, in that is a sure bet that you will be buying a new trans.You need CVT fluid from the dealership.
JohnHancock 01-08-2013 09:31 PM
Ok that's what I wanted to know. So it needs cvtf+4
JeepCares 01-10-2013 07:09 AM
How did you determine that you needed trans fluid?
JohnHancock 01-10-2013 11:06 AM
A local mech had the measuring tool from the dealer. He checked it and put like half a quart of cvt. which fixed the problems
tjkj2002 01-10-2013 08:08 PM
So you going to fix the leak? The fluid just does not disappear.
FujativeOCR 01-10-2013 09:13 PM
And was there any burned fluid inside it? Some signs of early cvt failure might be burned fluid.
JohnHancock 01-10-2013 09:36 PM
Ill have to check for leaks.
The time now is 10:49 AM.
