It's the top slide pin and it's seized. The brake line is right behind the bolt.
How the hell can I remove this bolt without removing the brake line? I noticed it was seized when I was doing the rear brakes. I couldn't rotate the caliper upwards and had to use a pry bar to move it.
I live in Michigan and the salt has probably made the bolt impossible to remove. I heard an open end wrench can strip the head. I have a small propane torch, will this work? I use this torch all the time on suspension bolts.
Can I loosen this bolt enough to where the caliper will come off?
