2009 Compass Ralleye engine question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Compass & Patriot Forum > 2009 Compass Ralleye engine question
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 01-16-2013, 06:31 PM   #1
lidhead
2009 MK Compass
Has anyone else had engine problems like mine? If I do not let the engine warm up for at least 3 minutes it will stall when I try to shift into second gear. Also, sometimes I cannot rev it past 4,000 RPM, and when this happens the cruise control will not work either. I am not sure how often the RPM happens, because it is rare that I rev it that hard, but I do notice the cruise control issue fairly often. Can anyone help me?
2009 Compass Rallye
"Free lovin' don't cost a dime"
lidhead is offline   Reply With Quote Quick reply to this message
Unread 01-19-2013, 07:52 AM   #2
pinstripefan90
1994 ZJ
Have you checked for dtcs, and does the red lightning bolt symbol ever come on the dash? One possibility is the throttle body but w out any data or testing your guess is as good as mine
pinstripefan90 is offline   Reply With Quote Quick reply to this message
Unread 01-26-2013, 06:24 AM   #3
lidhead
2009 MK Compass
I have never seen the "red lightning bolt" come on. I have taken it to the dealer with no luck. I thought maybe someone here might have had the same problem. But right now we have some fresh snow, and I'm having a little fun If I do find the problem I will be sure to post it.
2009 Compass Rallye
