2008 patriot trans slip - JeepForum.com
Go Back JeepForum.com > Models > Compass & Patriot Forum > 2008 patriot trans slip
Rough Country Lift Kits now available at Baseline 4x4 OutfHeavy Duty 2007-2013 Jeep JK Wrangler Perfmance Ball Joint1 Ton Heavy Duty Steering Upgrade Kit. New and Improved d
Unread 03-20-2015, 09:52 AM   #1
billwoot
Hey everyone I have an 08 patriot with what seems to be a trans slip. It's the 2.4L 4 cylinder. With CVT2 transmission I believe. 110k miles. Trans flushed at 100K. Shifts funny at lower speeds during acceleration. Any insight on what this could be?
99xj sport. 4.0 d30/c8.25. Aw4 np-231
billwoot is offline   Reply With Quote Quick reply to this message
Unread 03-20-2015, 02:41 PM   #2
Sdsjeep2008
2008 MK Compass
I have a 2008 Compass with the CVT transmission and 65K on the odometer.
There was a couple of times recently when I was accelerating up a hill that I thought it was slipping because the RPMs suddenly went up high. This is a hill I go up from a stop light every night on the way home from work so I've experimented with it since and have determined that if I don't give it enough throttle, the transmission kicks into overdrive mode and tries to get it moving up the hill. The speed limit is only 30 MPH up the hill so I don't want to give it too much gas or else it picks up and quickly goes to 40mph.
My point is that from what I've read, this should be happening.
I've also read that your RPMs should not really go up but your speed will increase slowly in certain cases and this seems to be while on level roads.
These transmissions definately operate and feel different from the regular old auto transmission. I'm still getting used to how mine operates.
Sdsjeep2008 is offline   Reply With Quote Quick reply to this message
Unread 03-20-2015, 03:50 PM   #3
billwoot
I get what your saying but, I'll be accelerating and my transmission will miss and subsequently the rpms will drop sharply, then catch and climb back up.
Unread 03-23-2015, 01:56 PM   #4
JeepCares
FCA Customer Care
JeepCares's Avatar
Hey billwoot,
Sorry to hear you are having issues with your vehicle. Have you had the concern inspected by your dealer?
Andrea
Jeep Social Care Specialist
JeepCares is offline   Reply With Quote Quick reply to this message
Unread 03-23-2015, 03:27 PM   #5
billwoot
Nope not yet. I was waiting to see if anyone on here had any advice first. I also have an xj and much help has come from the guys over there
Unread 03-26-2015, 03:08 PM   #6
JeepCares
FCA Customer Care
JeepCares's Avatar
Yes, the forums can be a great resource. Let me know if you have any additional questions.
Andrea
