2008 Patriot help. 108k what do I need done? - JeepForum.com
post #1 of 2 Old 09-22-2012, 09:02 PM Thread Starter
11Past9
My wifey has a 2008 Jeep Patriot that's loaded with everything but leather, it's a 5 speed manual w the bigger engine option. What does she need to make sure is done, it runs and drives fine. The dealer said she has a timing chain not a belt but I'm concerned. What do I need to make sure is done for important maintenance?
11Past9 is offline
post #2 of 2 Old 09-23-2012, 07:35 AM
cuemark8
2007 MK Compass
Did u change transmission fluid? I did with mine. You should change it at least every 100K. There are links to do this change. Search this site. Being the manual, it's not hard it can be done yourself. It's as easy changing engine oil. However you may need a pump or hose to get fluid back into transmission. It in a tight spot where you just can't simply pour it from the bottle. Tranny uses ATF+4 fluid. The MOPAR factory fluid is actually really good stuff and synthetic. Being a manual there is no transmission filter no dipstick either. You fill in the the upper hole on side of transmission case until it runs out. Lower plug is obviuosly the drain.
Need about 3.5 qts.
Also with 108K I assumed you have changed the spark plugs before?
How about the radiator and coolant change? Go to dealer for this. Don't mess with having to get rid of the coolant yourself. Should be no more than $100. It's got the red coolant good for 150k mi. I think thats a long time to go without a change. I changed mine at 100k.
Dealer is right, there is no timing belt, oil bathed timing chain instead. Don't worry about it. It will outlast the engine and vehicle.
FYI. I'm the guy who just hit over 200K on my 2007 Compass FWD 5-speed.
cuemark8 is offline
2008 jeep patriot stevendavis Jeep Compass & Patriot Forum 3 09-14-2012 02:39 PM
Jeep Patriot 2.0 crd 2008 cca100 Jeep Compass & Patriot Forum 3 06-17-2012 07:53 PM
2008 Patriot lift kit HELP armystrong68w Jeep Compass & Patriot Forum 20 12-19-2010 09:44 PM
2008 Patriot & Compass unclejjg Jeep Compass & Patriot Forum 25 10-21-2007 06:50 AM
2008 Patriot price amy123 Jeep Compass & Patriot Forum 3 07-16-2007 08:44 PM
