2008 Patriot Fuel Pumping Problem - JeepForum.com
Go Back JeepForum.com > Models > Compass & Patriot Forum > 2008 Patriot Fuel Pumping Problem
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineORS Recovery RopeSynthetic Winch Rope from ORS
Unread 12-17-2014, 12:41 PM   #1
greygoat
The pump at the gas station keeps shutting off before gas tank is filled. Took it to dealer who installed new fuel filler neck. Same problem. Took it back today and was told the valve at the gas tank does not work and that a piece of it has fallen into the gas tank. 1) Is it safe to drive the Patriot with a piece of valve in the gas tank? 2) Does it sound like the dealer knows what the problem really is? 3) Any ideas of what could really be the problem?
greygoat is offline   Reply With Quote Quick reply to this message
Unread 12-18-2014, 04:05 PM   #2
JeepCACares
greygoat,
I'm sorry to hear about your fuel tank concerns. In regards to the dealer diagnosis, your Service Adviser and technician will be able to elaborate on the evidence indicating the valve location.
You may also follow-up with the Service Manager as well.
Dave P.
Top Care Specialist
Chrysler Canada
JeepCACares is offline   Reply With Quote Quick reply to this message
Unread 01-21-2015, 10:31 PM   #3
kadetklapp
1997 XJ Cherokee
The fuel tank vent is plugged or has disentigrated and clogged itself. Mine does this as well, I have to set the pump to the second click and eek the fuel in slowly.
**1997 Jeep Cherokee SE**
Former Police Car
2008 "Jeep" Patriot <-----Crap.
kadetklapp is offline   Reply With Quote Quick reply to this message
