2008 Patriot - brake/traction light stays on...bad braking - JeepForum.com
post #1 of 3 Old 09-23-2012, 11:35 PM Thread Starter
TXST8tj
TXST8tj's Avatar
My sister has a 2008 Patriot. The brake assist/traction control light constantly comes on the dash. While the light is on, the braking is...spongy. Maybe a bad descriptor, but the braking is poor.
She thought it was the actual brakes, so I checked them and rotors and pads are perfectly fine, as well as fluid.
Is this something that just requires a reset, or is there something more wrong?
Patrick
TXST8tj is offline
post #2 of 3 Old 09-23-2012, 11:44 PM
FujativeOCR
2011 MK Patriot
Sounds like another bad wheel speed sensor. Seen a few of those on here lately. There are sensors in the hubs that measure how fast each wheel spins. If one slows down or stops in relation to the rest, the traction control or ABS will compensate as it calculates necessary. Maybe with a bad sensor it thinks you are skidding, and releases the brakes, which it thinks will get the wheels spinning again.
FujativeOCR is offline
post #3 of 3 Old 09-27-2012, 04:34 PM Thread Starter
TXST8tj
TXST8tj's Avatar
Has anyone done a writeup on replacing these?
Is there anyway to tell which one(s) it is?
It makes sense that it could be the problem.
Patrick
TXST8tj is offline
2008 Patriot help. 108k what do I need done? 11Past9 Jeep Compass & Patriot Forum 1 09-23-2012 08:35 AM
2008 jeep patriot stevendavis Jeep Compass & Patriot Forum 3 09-14-2012 03:39 PM
Jeep Patriot 2.0 crd 2008 cca100 Jeep Compass & Patriot Forum 3 06-17-2012 08:53 PM
Patriot 4x4 2008 transmission f_chabot Jeep Compass & Patriot Forum 3 09-07-2008 07:36 AM
2008 Patriot price amy123 Jeep Compass & Patriot Forum 3 07-16-2007 09:44 PM
