2008 Jeep Patriot - Issues with HID Lights - JeepForum.com
post #1 of 19 Old 09-11-2008, 08:25 AM Thread Starter
KD2008
I have been having an issue with my 2008 Jeep Patriot. My starter malfunctioned two weeks ago and was replaced. I was told that there was a hole in my starter. That was two weeks ago. The other day, after putting my car in park and taking the key out of the ignition, my car continued to run making the noise as if I try to start the car while the car was still running. I took it to the dealer to look at. I was told that the HID kit that was installed on my car was causing an issue with the TIPM Module. It would need to be replaced for $600. I am not sure if this is right and if the issue with my starter could have caused the problem not the lights. Please help.
KD2008 is offline
post #2 of 19 Old 09-11-2008, 01:22 PM
merlinTec
merlinTec's Avatar
Hi
The TIPM controls both but can't see how one could affect the other.
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #3 of 19 Old 09-11-2008, 02:03 PM Thread Starter
KD2008
Thanks for your response. I was told that the lights are causing a power surge that affected the TIPM and therefore causing problems with the replaced starter. Does this make sense?
KD2008 is offline
post #4 of 19 Old 09-11-2008, 04:53 PM
merlinTec
merlinTec's Avatar
Hi
No how have you got them wired up? TIMP will monitor the lighting circuit and will shut off the lights if it draws too much current or too little current and that’s why some that have done this conversion complain of flickering.
post #5 of 19 Old 09-12-2008, 10:40 AM
ErikRP
2017 WK
You might want to try the Compass & Patriot forum for better response.
2017 Grand Cherokee Summit - Granite Crystal Metallic
Yes, it's got a Hemi!
ErikRP is offline
post #6 of 19 Old 09-13-2008, 03:53 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
We have another thread on this same issue with HID's and starters. I'll need to look for it later. Thanks Merlin for bringing this to my attention.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #7 of 19 Old 09-15-2008, 07:39 PM
KRICKETCOMPASS
2008 MK Compass
my compass did the same thing and then i decided to unplug the lights real quick and called the company i got the kit from and they said i needed a low beam harness i ordered it tonight when it comes in i will let you all kno how the install was and if it fixed the problem
KRICKETCOMPASS is offline
post #8 of 19 Old 09-17-2008, 01:44 AM
madrabbitt
madrabbitt's Avatar
gramps, where is the other thread?
Installing HID's in stock housings is bad.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline
post #9 of 19 Old 09-17-2008, 04:58 AM
CharBroiled
here.
2000 Cherokee Sport 4.0L Selec Trac - mine - for occasional wheeling
2007 Patriot 2.4L FD I 4x4 - wifes - doomed to rarely leave the street
CharBroiled is offline
post #10 of 19 Old 09-17-2008, 05:28 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
There are 3 threads going on the same issue. 2 titled with HID and one titled as Starter. Here's the other: http://www.jeepforum.com/forum/f98/2007-compass-starter-motor-problems-602931/
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #11 of 19 Old 09-17-2008, 05:56 PM
madrabbitt
madrabbitt's Avatar
So, it looks like the TIPM isnt well shielded... design flaw?
BTW. Its not VOLTAGE and voltage drops causing issues with the HIDs, its probably spikes in amp draw or volt draw.
post #12 of 19 Old 10-08-2010, 10:16 AM
macman24
2008 MK Patriot
hid's and starters
my 2008 patriot has hid's but they flicker. took it to a place where install hid's and told them my problem.they check the wiring and fuses and ground. they said i needed a compositor, they put it in and watched for any flickering.. 2min later the starter is trying to turn on while the car is running. we try it again with a different compositor and the same problem with the starter came up
macman24 is offline
post #13 of 19 Old 10-09-2010, 10:15 AM
macman24
2008 MK Patriot
H13/9008 replacement bulbs
would it be better to put H13/9008 replacement bulbs on my 2008 jeep patriot instead of putting the hid kit
macman24 is offline
post #14 of 19 Old 10-09-2010, 11:51 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I put the Sylvania SilverStars in mine because of the feedback on HID's (and the fact that blinding others doesn't seem like the right thing to do) and I am VERY happy with them!
More info here: http://www.jeepforum.com/forum/f98/c...lights-879565/
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #15 of 19 Old 10-13-2010, 01:10 PM
macman24
2008 MK Patriot
hid's and starters
can the hid be installed by connecting the whole hid setup straight to the battery and just having a on and off switch connected
macman24 is offline
compass , HID light problem , mk , patriot , tipm
2008 Patriot Wheels vapors1 Jeep Compass & Patriot Forum 5 05-31-2011 10:11 PM
Headrest Problem On 2008 Patriot ChillyWillys Jeep Compass & Patriot Forum 16 08-24-2009 08:59 PM
Patriot 4x4 2008 transmission f_chabot Jeep Compass & Patriot Forum 3 09-07-2008 06:36 AM
2008 Patriot & Compass unclejjg Jeep Compass & Patriot Forum 25 10-21-2007 06:50 AM
2008 Patriot price amy123 Jeep Compass & Patriot Forum 3 07-16-2007 08:44 PM
