2008 jeep patriot - JeepForum.com
post #1 of 4 Old 09-12-2012, 09:05 AM Thread Starter
stevendavis
2008 jeep patriot
I have a 2008 jeep patriot and it has a code intake manifold running valve stuck open. Anyone with and info on how to fix it please reply to my post dont want to put it in shop and pay thousands to fix it. Would like to fix myself. Thanks
stevendavis is offline
post #2 of 4 Old 09-12-2012, 01:05 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
I wonder if this is what you have for a code:
P2004-INTAKE MANIFOLD RUNNER CONTROL STUCK OPEN
From the service manual:
When Monitored:
With the engine running, when the valve closes, below a calibrated RPM, depending upon pedal position.
Set Condition:
The Powertrain Control Module (PCM) detects that the position feedback of the Manifold Flow Valve Position Sensor is not within range of the adapted value learned during in-plant initialization or after a non volatile memory reset (adaptive memory clear).
Possible Causes:
  • (K857) 5-VOLT SUPPLY CIRCUIT SHORTED TO VOLTAGE
  • (K602) MFV SIGNAL CIRCUIT SHORTED TO VOLTAGE
  • (K857) 5-VOLT SUPPLY CIRCUIT SHORTED TO GROUND
  • (K602) MFV SIGNAL CIRCUIT SHORTED TO GROUND
  • (K857) 5-VOLT SUPPLY CIRCUIT SHORTED TO (K900) SENSOR GROUND CIRCUIT
  • (K602) MFV SIGNAL CIRCUIT SHORTED TO (K900) SENSOR GROUND CIRCUIT
  • (K602) MFV SIGNAL CIRCUIT SHORTED TO THE (K857) 5-VOLT SUPPLY CIRCUIT
  • (K857) 5-VOLT SUPPLY CIRCUIT OPEN OR HIGH RESISTANCE
  • (K602) MFV SIGNAL CIRCUIT OPEN OR HIGH RESISTANCE
  • (K900) SENSOR GROUND CIRCUIT OPEN OR HIGH RESISTANCE
  • (Z909) GROUND CIRCUIT OPEN OR HIGH RESISTANCE
  • MANIFOLD FLOW VALVE
  • INTAKE MANIFOLD
  • POWERTRAIN CONTROL MODULE (PCM)
JeepCares is online now
post #3 of 4 Old 09-12-2012, 07:20 PM Thread Starter
stevendavis
Thats exactly what it is p2004 is there an easy fix someone told me maybe the map sensor. I need some more good info. New to the jeep world and am loving it alot plan on buying more jeeps in future.
post #4 of 4 Old 09-14-2012, 02:39 PM
LS1_DOC
Junior Member
It is usually a warped intake manifold not allowing the runner valve to come back to the proper position. You can try and replace the valve assembly itself but if the code comes back it will need the intake manifold.
LS1_DOC is offline
