2008 Jeep Compass Rallye Edition (Clunking in the rear) - JeepForum.com
Go Back JeepForum.com > Models > Compass & Patriot Forum > 2008 Jeep Compass Rallye Edition (Clunking in the rear)
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 06-10-2010, 06:16 PM   #1
Matthew1785
Good afternoon.
I dont post here much. But im having an irritating problem with my 2008 jeep compass. I took it to the dealership a few days ago due to clunking in the rear. The told me it was the struts and the strut plates on both sides.. I got the car back today and its still making a clunking noise.
The clunking noise happens only when i make a sharp turn and it literally sounds like a clunk, clunk noise. What else could it be that would cause that noise. its driving me nuts. My only other guess is it could be sway bar and or the sway bar bushings? I have a receipt from the dealership of the parts they ordered and replaced..
Please someone give me some insight its driving me nuts!
Matthew1785 is offline   Reply With Quote
Unread 06-11-2010, 04:35 AM   #2
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
This only applies to '09 's but is worth looking at http://www.wkjeeps.com/misc/Caliber/...onse_09057.pdf
I've also heard of the rear control arm bushings "walking out" which usually causes a squeak but in theory could cause a clunk too.
Bob
MK Skid Plate fasteners for sale posts 68 & 69
Also visit me at Photobucket
Gramps is offline   Reply With Quote
Unread 06-11-2010, 01:16 PM   #3
Matthew1785
Thanks Gramps.
I showed them the TSB and they said that there is a difference between the 08-09's suspension
I took back to the dealership and had the mechanic who worked on it, test drive the car with me, and he wants to dismiss it as the plastic in the wheel well shifting with weight of the car.. I can tell you right now i honestly dont think thats the cause.. I could drive the car at 10-15 miles an hour and STILL hear the clunking in the rear, it sounds as if IMO it might be muffler mounts or the exhaust moving.. but thats more like a rattling i would assume. the sound i hear is a clunking sound as if something is shifting side to side
Does anyone has a layout of the rear suspension of this model?
Unread 06-11-2010, 02:54 PM   #4
jacko15
2014 WK
Once owned a Dodge Caravan with a similar clunking sound. Turned out it was a tool bouncing around in the unibody cavity. Drove me nuts. I was lucky my mechanic was able to isolate and quiet it. Hope yours is something easier. Good luck!
jacko15 is offline   Reply With Quote
Unread 06-14-2010, 05:45 PM   #5
nettolt
2007 MK Compass
When I turn a tight left I can hear a horrid noise like a spring stretching, same situation as you, the dealer doesn't know nor do they car. I can tell you however, that I wouldnt be shocked if it was the rear control arms like gramp mentioned. I may bring this up next time I make an appointment after I get new brakes on so they can stop blaming it on them.
'07 Compass -> I apologize to the next owner.
nettolt is offline   Reply With Quote
Unread 06-27-2010, 06:53 PM   #6
TedH
Have them check out the rear Toe Links semi common problem with the MK's and PM's
TedH is offline   Reply With Quote
Unread 07-04-2010, 02:10 PM   #7
Steiner
Good day, I had the same problem. It turn out to be the free play of the muffler's isolators or rubbers that was to great, and was hitting the tow package installed on my Compass. To resolve the problem, I grinded the corner that was too close to the itch mounting plate. Also, make sure your isolators are all in good condition.
Steiner is offline   Reply With Quote
Unread 03-05-2013, 01:56 PM   #8
Matthew1785
Incase anyone care's that clunking in the rear was caused by the bushing in the rear upper control arms.. they were replaced last week, now i have a new problem.. knocking at low speeds in the rear
compass , rallye , rear clunk , rear noise
