2008 Jeep Compass main brake lights not working. - JeepForum.com
Go Back JeepForum.com > Models > Compass & Patriot Forum > 2008 Jeep Compass main brake lights not working.
Savvy Billet LED Tail LightsFS: Jeep Fog Light LED Bulbs! Several Brightness Options! Jeep Wrangler Complete Gear Upgrade Kits with Installs and
Unread 01-14-2015, 06:09 PM   #1
rjtneilson
2008 MK Compass
The 3rd high mount lamp does come on when brakes are pressed, the two side lights do not. Turn on night lights and the two side lights do turn on, but do not illuminate more when brakes are pressed. I am guessing the lights are okay, could it be a fuse issue? Should I replace the lights and see if that works?
rjtneilson is offline   Reply With Quote Quick reply to this message
Unread 01-15-2015, 07:23 AM   #2
JeepCACares
rjtneilson,
I'm sorry to hear about your brake lamp concerns. In addition to a possible bulb concern, is possible your symptom may be related to the brake lamp switch as well.
Dave P.
Top Care Specialist
Chrysler Canada
JeepCACares is offline   Reply With Quote Quick reply to this message
Unread 01-15-2015, 07:41 AM   #3
Sdsjeep2008
2008 MK Compass
The side lights are not the same as the brake lights. In some cars, the side light might still work but the brake light part of the bulb doesn't work. It seems odd that both sides are out at the same time. I would think the brake switch that activated the third brake light is working correctly since it did activate the third brake light. I would start with the easiest and cheapest fix by replacing the bulbs on each side.
Sdsjeep2008 is offline   Reply With Quote Quick reply to this message
Unread 01-16-2015, 06:23 PM   #4
rjtneilson
2008 MK Compass
I did replace each bulb and works fine now, must have been the problem. The bulbs looked to have partially burnt out. Glad it was easy fix and not the brake switch or other.
Thanks for the suggestions and help!
Unread 01-19-2015, 07:24 AM   #5
JeepCACares
rjtneilson,
Great news, I'm pleased to hear everything has been resolved.
Dave P.
Top Care Specialist
Chrysler Canada
