2008 Compass wont start, battery is fine - JeepForum.com
post #1 of 5 Old 01-16-2011, 09:17 PM Thread Starter
heslop2011
Hi all, need input from anyone who had the same problem. My 2008 compass wont start, I checked my battery and reads over 12 volts. I had a problem a couple of weeks ago, it took a couple of tries to get the jeep to start. I took it to the dealer and the code they found was saying the key is not recognized. So they cleared the code and it worked fine for a week and now it wont start at all, engine wont turn over. Owners manual is no help... I didn't see a starter relay in the fuse box and also I can't find where the starter motor so I can tap it with a hammer if it is a starter issue. Any feedback will be great help. Thanks.
heslop2011 is offline
post #2 of 5 Old 01-16-2011, 11:58 PM
Urr
Check the ground wire, just in case.
See here (#13): http://www.jeepforum.com/forum/f98/2...old-945359/#13
Happiness is not a goal, but a lifestyle
Ex 2007 Jeep Compass Sport 4x4 CRD
DD 2011 Mitsubishi ASX Invite 4WD DiD
In bright and happy future: Jeep Wrangler
Urr is offline
post #3 of 5 Old 01-17-2011, 07:08 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
It sounds like it won't even crank. Even a key with no chip will allow it to do that, it just won't fire or will fire and then die.
If you could call them up and find out what the # code was, like Bxxxx, that would help.
It could be the 10a fused ignition switch output in the TIPM or the TIPM itself is bad.
or
The Occupant Restraint Controller
or
The Transmission Range Sensor.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #4 of 5 Old 01-21-2011, 06:13 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Check out this TSB and see if it fits your problem.
http://www.wkjeeps.com/misc/Caliber/...r_0800708a.pdf
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #5 of 5 Old 01-03-2017, 07:32 PM
Jack16
Ok so I have a 2008 compass no crank no start battery is good pulled starter control wire jumped it to battery and it cranked over but no fire. So found relay box down behind headlight pulled the relays to find tab on one corroded off $20 later and a few curse words hit the key and bam it was running. I hope this helps
Jack16 is offline
2008 Compass power windows. horsepower Jeep Compass & Patriot Forum 9 08-25-2009 03:45 PM
2008 Compass Rally question... Sgt_K Jeep Compass & Patriot Forum 1 05-17-2009 03:34 PM
My 2008 Compass with a little modification horsey2k Jeep Compass & Patriot Forum 4 11-18-2008 12:56 PM
2008 compass body parts? bobsj2000 Jeep Compass & Patriot Forum 2 08-19-2008 03:59 AM
2008 Patriot & Compass unclejjg Jeep Compass & Patriot Forum 25 10-21-2007 06:50 AM
