2008 Compass Dashboard Question, GPS antenna removal - JeepForum.com
post #1 of 6 Old 04-19-2010, 05:59 PM Thread Starter
Sprimo973
2008 MK Compass
I am looking to gain access to my GPS antenna located under the "hump" in the middle of the dashboard on my 2008 Jeep Compass.
Does anyway know how to go about removing the cover to the "hump"...do you just pop it up with something like a screwdriver, or should I take off the Bezel first or is that unnecessary?
Thanks
Sprimo973 is offline
post #2 of 6 Old 04-19-2010, 06:21 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
There are some screws holding stuff in that need to be removed. Take a look at this and see if it helps.
http://www.jeepforum.com/forum/f98/a...ml#post4032179
You don't need to remove the radio/Nav unit but the bezels to come off to gain access.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 6 Old 04-20-2010, 09:45 AM
w4rh4wk
2011 MK Compass
I've done it a ton of times. Download this
http://site.justforjeeps.com/guide/82209617.pdf
Look for "Jeep Compass/Patriot" on the top of the page and the bottom says
"Page 20 of 22" Steps 1-3
11 Compass 2.4 4x4, Eonon GA2162, K&N Intake, Magnaflow #16777, Mopar:Chrome Fuel Door/Splash Guards
w4rh4wk is offline
post #4 of 6 Old 04-20-2010, 11:12 AM Thread Starter
Sprimo973
2008 MK Compass
Thank you guys for your help, Warhawk..i have seen this and I never understood on the Step 3 picture what that paper clip-esk looking symbol means...I figured it meant pry it up and out...
post #5 of 6 Old 04-20-2010, 11:17 AM
w4rh4wk
2011 MK Compass
Yeah its a pry tool. You dont really need that. I just used my hands and pull upwards on the two front corners first and then the 2 rear corners to remove top center piece that you want to get into. Takes a little bit of pressure.
w4rh4wk is offline
post #6 of 6 Old 04-20-2010, 02:43 PM Thread Starter
Sprimo973
2008 MK Compass
Thank you guys, much appreciated!
antenna , center stack , compass , dash , gps , patriot
2008 Compass power windows. horsepower Jeep Compass & Patriot Forum 9 08-25-2009 03:45 PM
2008 Compass Rally question... Sgt_K Jeep Compass & Patriot Forum 1 05-17-2009 03:34 PM
My 2008 Compass with a little modification horsey2k Jeep Compass & Patriot Forum 4 11-18-2008 12:56 PM
Sirius Antenna Installation on a Compass tryinginvain Jeep Compass & Patriot Forum 4 05-27-2008 06:13 PM
2008 Patriot & Compass unclejjg Jeep Compass & Patriot Forum 25 10-21-2007 06:50 AM
