2007 Patriot front end - JeepForum.com
post #1 of 10 Old 01-23-2012, 01:03 PM Thread Starter
pafishman
2007 MK Patriot
Has anyone seen anything on these 07's needing ball joints and tie rod ends? I've had the tie rod ends replaced @ 42,000 miles and now I think the lower ball joint is also bad @ 45,000 miles.
pafishman is offline
post #2 of 10 Old 01-23-2012, 01:27 PM
IRSmart
2015 KL Cherokee
yes, the early MK models had pre-mature ball joint failure. Gramps, what is the brand that is recommended to replace them with?
IRSmart is offline
post #3 of 10 Old 01-24-2012, 06:51 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
MOOG is the brand to get. Just call around and see which of the local stores carry that brand. MOOG has the grease fittings that will add to your 'tune-up time' but they will last longer if not neglected.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #4 of 10 Old 01-25-2012, 07:55 AM Thread Starter
pafishman
2007 MK Patriot
I can’t be leave that there is no recall on this problem
post #5 of 10 Old 01-29-2012, 11:39 PM
the_jeep_now
2010 MK Patriot
It's the most common problem of MKs. The other jeep patriot forum is flooded with complaints about it but as mentioned Moog carries greasible parts with lifetime warranty.
the_jeep_now is offline
post #6 of 10 Old 01-30-2012, 09:05 AM Thread Starter
pafishman
2007 MK Patriot
Well I just got more bad news on saturday, I also need ball joints with 43,600 miles !
post #7 of 10 Old 01-30-2012, 09:38 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
That's about when mine went out.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #8 of 10 Old 02-03-2012, 05:53 PM
festerw
festerw's Avatar
I had one go out at around 50k replaced under warranty and replaced both of them around 80k with Moog.
I've also replaced front sway bar links (Moog), front sway bar bushings (Energy), left side tie rod (Mopar), rear toe links (Mopar) and struts (Mopar) all around.
It still clunks and rattles, drives me crazy that no one can find it the dealer and two independent mechanics have looked at it. Still drives straight and tire wear is normal though.
I guess my point is hopefully for you ball joints fix it.
Hers - 2011 Dodge Durango Crew
Mine - 2003 Jeep Wrangler X
1998 Jeep Cherokee Classic
festerw is offline
post #9 of 10 Old 02-03-2012, 06:29 PM
FujativeOCR
2011 MK Patriot
So glad I bought the Maximum Care Plus thingy from Chrysler.
Looks like both Ball joints and Tie Rod ends are covered.
http://www.extended-warranty-pro.com..._coverage.html
FujativeOCR is offline
post #10 of 10 Old 02-04-2012, 06:37 AM
IRSmart
2015 KL Cherokee
IRSmart is offline
2007 patriot 2.4l sometime wants to start but doesn't misfitJason Jeep Compass & Patriot Forum 11 01-13-2012 08:40 PM
2007 Patriot with clunk Gav'spurplez Jeep Compass & Patriot Forum 5 09-11-2010 10:45 PM
New-to me-2007 Patriot Limited Kulae Jeep Compass & Patriot Forum 1 02-16-2010 01:47 PM
2007 Patriot Flooding Pizon Jeep Compass & Patriot Forum 2 11-28-2009 12:45 PM
2007 Patriot Sport Pizon Jeep Compass & Patriot Forum 1 11-14-2009 04:48 PM
