2007 patriot 2.4l sometime wants to start but doesn't - JeepForum.com
post #1 of 12 Old 12-13-2011, 04:17 AM Thread Starter
misfitJason
I just replaced the battery a month ago. Double checked the grounds....all good. I will turn the key and it wants to start up but sputters out and dies. It' not the type of not starting like an alternator problem or battery problem (click,click,click). It has plenty of electrical juice. Any ideas or anyone elses do this. The jeep has 40k on the clock and it perplexes me.
misfitJason is offline
post #2 of 12 Old 12-13-2011, 07:44 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
It boils down to either spark or fuel.
You have juice from the battery but is it getting to the plugs?
Fuel - bad pump, filter or injector?
Does it eventually start? If it does get it to some place that can pull the codes.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 12 Old 12-13-2011, 01:51 PM Thread Starter
misfitJason
it's not throwing any codes at all. Plugs are good and spark is there. Also i have replace the air filter when I did the battery. It's wierd because it does it intermittently. I can never tell when it is going to do it.
post #4 of 12 Old 12-13-2011, 06:54 PM
dgilluly
My friend's Volvo was doing something very similar. Turned out to be a defective starter. Some engines are picky about the starter getting them up to full speed.
I'm a college student and self-employed computer technician.
CompTIA A+ certified, and soon to be CompTIA Network+ certified as well
I currently own a 1995 Jeep Grand Cherokee, pretty much all stock instead of the sound system.
dgilluly is offline
post #5 of 12 Old 12-14-2011, 04:27 PM
miketmx
2015 MK Patriot
Have you replaced the battery in your key ?
miketmx is offline
post #6 of 12 Old 12-14-2011, 08:55 PM Thread Starter
misfitJason
No I haven't replaced the battery in the key at all since she got the jeep. As far as the starter it's cranking fine I have done quite a bit of work to jeeps in the past which is why I am thinking fuel is the problem but the not producing error codes thing is throwing me off. (carb jeeps)(cjs)
post #7 of 12 Old 12-15-2011, 02:05 PM
miketmx
2015 MK Patriot
I'm suggesting that you replace the battery in the key for what little it costs. The little chip in the key can do weird things to the security system.
miketmx is offline
post #8 of 12 Old 12-16-2011, 08:19 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Yes it could be the battery in the key is low and not letting it communicate with the Sentry System. It's a cheap fix if that's it. The surfaces on the battery also build up oxidation and maybe just a cleaning could help.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #9 of 12 Old 12-16-2011, 11:03 AM
Coasty161
Make sure all the fuses are seated correctly...this was a cause of no starts on the compass when we had it.
Sent from my SPH-D700 using JeepForum
Silver WK Club Member #21
2007 Jeep Compass (sold)
2008 Jeep Grand Cherokee (sold)
2008 Jeep Wrangler unlimited 4d (current)
2012 Dodge Durango (current)
Coasty161 is offline
post #10 of 12 Old 12-16-2011, 08:19 PM Thread Starter
misfitJason
Battery in the jeep is not corroded it's brand new. The terminals are t corroded. I will try replacing the key battery but it has no security system
post #11 of 12 Old 12-17-2011, 08:29 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
All Jeeps have the Sentry Key, that's what I was referring to, not the alarm system. There is a battery powered chip in it that communicates with the SCREEM that allows it to start. I understand that the 12v main battery is new and shouldn't be the problem. Re-seating the fuses inside the TIPM may help too as 07compasssport mentioned.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #12 of 12 Old 01-13-2012, 08:40 PM Thread Starter
misfitJason
well did the key change deal and that was and is not the problem. I am having her run some fuel system cleaner through it to see if that help after two tanks full of gas. It apparently only does it when it is cold. So if the fuel injector cleaner doesn't work I will probably drop the fuel tank to check out the punp because that is what makes the most sense that could be bad possibly due to gas being so ****ty these days with ethanol.
2007 Patriot with clunk Gav'spurplez Jeep Compass & Patriot Forum 5 09-11-2010 10:45 PM
New-to me-2007 Patriot Limited Kulae Jeep Compass & Patriot Forum 1 02-16-2010 01:47 PM
2007 Patriot Flooding Pizon Jeep Compass & Patriot Forum 2 11-28-2009 12:45 PM
2007 Patriot Sport Pizon Jeep Compass & Patriot Forum 1 11-14-2009 04:48 PM
Remote start for 2007 Patriot tdawgui Jeep Compass & Patriot Forum 1 10-27-2009 07:12 PM
