2007 models? - JeepForum.com
post #1 of 5 Old 03-09-2012, 09:12 AM Thread Starter
aroundincircles
1989 XJ Cherokee
2007 models?
I am looking for trail rated patriots. I've been determining them on websites based on 2 things, does it have tow hooks, and does it have the low range gearbox? for 2007, it seems like even the non trail rated jeeps have the low range vs. the shift lever, is that correct? should i be basing it off if the vehilce has tow hooks only?
aroundincircles is offline
post #2 of 5 Old 03-09-2012, 10:00 PM
fortuneer
fortuneer's Avatar
2007 MK Compass
Actually, the L on the shifter (I'm assuming here that you're talking about the CVT-2 & not the 5-speed) is to keep the transaxle in it's lowest gear ratio, as it is with regular "geared" transmissions. The trail rated Patriot's "first" gear is a lower ratio than the standard model so you can crawl at extra low speeds without over reving the engine. Come to think of it, I don't remember if the 2007 Patriot had a trail rated version. Anyway, no 2x4 or 4x4 Pats came with tow hooks except in trail rated. They could be added by owners later. Hope this helps some.
"There's gold in them hills" (and I'm still stuck in Florida!) ...well, in south Miss now, lol
Black '07 Compass Sport 5-speed 4X4 ("Fortuneer"), K&N filter, cat-back exhaust; RR lift, sunroof, trailer tow group, Boston Acoustic audio, sport bars, rear taillight guards, more to come... Finally got it back from the wife so I can let my Neon R/T rest for a rebuild.
fortuneer is offline
post #3 of 5 Old 03-09-2012, 11:03 PM
festerw
festerw's Avatar
You are correct that all 07 Patriots had the L on the shift selector.
Hers - 2011 Dodge Durango Crew
Mine - 2003 Jeep Wrangler X
1998 Jeep Cherokee Classic
festerw is online now
post #4 of 5 Old 03-10-2012, 08:53 AM
FujativeOCR
2011 MK Patriot
I argue that not only the first gear is the lower ratio on TR Patriots. There is a reason that Trail Rated ones run at 3,000 RPM at Freeway speeds and Non TrailRated ones are about 2,000. All the ratios are different.
FujativeOCR is offline
post #5 of 5 Old 03-11-2012, 11:02 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
It's the transaxle that has the lower final drive ratios not the transmission itself giving you a lower ratio in all gears, i.e. the ring and pinion. The '07 Patriots did NOT have an AutoStick option so they all will have an 'L'. The Skid Plates, tow hooks, off Road medallion on the drives side fender and the engine oil cooler could all be added even though most ppl would not go to that much effort.
The absolute best way, if you question it, is to take the VIN to a dealership and have it run. See if it says FD II, CVT2L and the options just mentioned.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
Euro models - which CRD engine? tfmr Jeep Compass & Patriot Forum 8 11-08-2010 03:21 PM
Chrysler announces Dodge Caliber, Jeep Compass recall 2007 models w4rh4wk Jeep Compass & Patriot Forum 8 06-29-2010 05:32 PM
Hi, I bought a new 2007 Inferno Red Compass Limited 2 days ago, yes-NEW 2007- Beware Jeep Compass & Patriot Forum 5 04-20-2009 06:40 AM
Chrysler's Project Genisis: Cutting models and consolidating unclejjg Jeep Compass & Patriot Forum 19 02-18-2008 12:06 PM
2007 Patriot Models... Dealer Deals? safaribabe Jeep Compass & Patriot Forum 7 09-12-2007 12:07 PM
