2007 Jeep Compass 2.4 The Cooling Fans wont come on - JeepForum.com
post #1 of 2 Old 08-26-2012, 12:05 PM Thread Starter
saviorcrash
2007 MK Compass
Hi
I have a problem with the cooling fans on my 2007 Jeep Compass. The fans themselves work just fine wired Directly to the battery to keep them running. This is what I have manage to find out on my own. Anyone have any ideal where the Fan Relays are?
RADIATOR FAN WILL NOT OPERATE, GAUGE READING HIGH OR HOT (POSSIBLE CAUSE)
1. Fan motor defective - Refer to appropriate Powertrain Diagnostic Procedures manual for operation of the scan tool. Repair as necessary.
2. Fan relay, powertrain control module (PCM) or engine coolant temperature sensor defective - Refer to appropriate Powertrain Diagnostic Procedures manual for operation of the scan tool. Repair as necessary.
3. Blown fuse in power distribution center (PDC) - Determine cause for blown fuse and repair as necessary.
saviorcrash is offline
post #2 of 2 Old 08-28-2012, 08:18 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
GAS ENGINE
Radiator fan operation is controlled by the Totally Integrated Power Module (TIPM), with inputs from the engine coolant temperature sensor, continuously variable transmission (CVT) oil temperature, and A/C head pressure. The (TIPM) turns on the fan through either the high or low speed fan relay. The PCM provides a ground to the relay's control circuit. The fan relays are located in the (TIPM) . Refer to the label beneath the (TIPM) cover for location of fan relays.
Hope this helps.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
2007 Jeep Compass Windshield Replacement fourheels Jeep Compass & Patriot Forum 11 02-22-2016 06:04 PM
2007 Jeep Compass Issue bazarsmash Jeep Compass & Patriot Forum 3 06-14-2012 02:53 PM
2007 JEEP Compass 4x4 limited BLK_Compass Jeep Compass & Patriot Forum 3 08-31-2011 06:24 PM
Jeep compass 2007 oil change compasser Jeep Compass & Patriot Forum 14 08-20-2010 11:03 PM
2007 jeep compass suspension 10MRC Jeep Compass & Patriot Forum 4 12-15-2009 10:55 PM
