18" Tire Choices ? - JeepForum.com
Go Back JeepForum.com > Models > Compass & Patriot Forum > 18" Tire Choices ?
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Rough Country Jeep Suspension Deals at Rockridge 4WD!Looking to re-gear?! CRAZY DEALS ON YUKON GEARS right here
Unread 01-11-2014, 11:08 PM   #1
Katmandu
18" Tire Choices ?
I'm thinking of replacing the OEM 215/55-18s with these 235/55-18s.
http://www.tirerack.com/tires/tires....lus+Technology
What size, make, model 18s you folks running ?
- 2013 Jeep Wrangler Sport S
- 2014 Jeep Compass Latitude 4x4
- 2012 Jeep Liberty Latitude 4x4 - gone
- 2005 Jeep Liberty Renegade Rocky Mountian Edition - gone
Katmandu is offline   Reply With Quote
Unread 01-12-2014, 06:23 AM   #2
NHPATRIOT
2014 KL Cherokee
They are going to be too wide without wheel spacers to kick the rims outward. You will rub on turns.
9" is max width on tires for the Compass/Patriot without mod's and even that can result in some rubbing at full lock.
The 235's are 9.25" wide. Height wise( OD )you would be ok. Width they aren't going to work.
2014 Jeep Cherokee
Latitude
3.2L Pentastar V6
Active Drive I
NHPATRIOT is offline   Reply With Quote
Unread 01-12-2014, 10:02 AM   #3
Katmandu
Good to know.
