09 Jeep Compass CVT Fluid Service - JeepForum.com
post #1 of 3 Old 04-14-2010, 04:56 PM Thread Starter
coke2430
I went to change the transmission fluid today but can't figure it out. There is just a plug. Any familiar with this? And do they know if this is a sealed transmission? Thanks.
coke2430 is offline
post #2 of 3 Old 04-14-2010, 05:56 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I do recommend taking it to the dealer or someone qualified.
FLUID AND STRAINER SERVICE
Pic A
1. Remove the bolts holding the oil pan (1) to the transaxle case.
2. Remove the oil pan from the transaxle case.
Pic B
3. Remove the oil pan gasket (1) from the transaxle case.
Pic C
4. Remove the bolts holding the oil strainer (1) to the valve body.
5. Remove the oil strainer.
6. Remove and discard the oil strainer o-ring.
Pic D
CAUTION: Do not re-use the o-ring. Apply CVT fluid when installing the o-ring.
7. Install the new o-ring (1) onto the new oil strainer.
Pic E
8. Install the new oil strainer (1) onto the control valve assembly. Install and tighten the mounting bolts to 8 Nˇm (70 in. lbs.).
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 3 Old 04-14-2010, 05:59 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Pic F
CAUTION: Do not re-use the oil pan gasket. Remove any moisture, oil, and used gasket material from the surface where the new gasket is to be installed. When installing the oil pan gasket, align the dowel pin with the dowel pin hole in the oil pan gasket.
Pic G
9. Install the oil pan gasket (1) onto the transaxle case.
Pic A
CAUTION: When installing the oil pan, align the dowel pin of the transaxle case with the dowel pin hole of the oil pan.
10. Install the oil pan on the transaxle case (1). Install and tighten the mounting bolts to 8 Nˇm (70 in.lbs.).
NOTE: Only transmission fluid of the type labeled MoparŽ CVTF+4 (Automatic Transmission Fluid) should be used in this transaxle.
TRANSMISSION FILL
To avoid overfilling transmission after a fluid change or overhaul, perform the following procedure:
1. Verify that the vehicle is parked on a level surface.
2. Remove the dipstick tube cap.
3. Add following initial quantity of MOPARŽ CVTF+4, Automatic Transmission Fluid, to the transmission:
a. If only fluid and filter were changed, add 7.0 L (14.8 pts.) of transmission fluid to transmission.
b. If the transmission was completely overhauled or the torque converter was replaced or drained, add [B]8.1 L (17.1 pts.) of transmission fluid to transmission.
4. Check the transmission fluid
CHECK OIL LEVEL
WARNING: There is a risk of accident from vehicle starting off by itself when engine is running. There is a risk of injury from contusions and burns if you insert your hands into the engine when it is started or when it is running. Secure vehicle to prevent it from moving off by itself. Wear properly fastened and close-fitting work clothes. Do not touch hot or rotating parts.
3. Actuate the service brake. Start engine and let it run at idle speed in selector lever position "P".
4. Shift through the transmission modes several times with the vehicle stationary and the engine idling.
5. Warm up the transmission, wait at least 2 minutes and check the oil level with the engine running. Push the Oil Dipstick 9336 into transmission fill tube until the dipstick tip contacts the oil pan and pull out again, read off oil level, repeat if necessary.
NOTE: The dipstick will protrude from the fill tube when installed.
See CVT TRANSMISSION FILL GRAPH
6. Check transmission oil temperature using the appropriate scan tool.
7. The transmission Oil Dipstick 9336 has indicator marks every 10 mm. Determine the height of the oil level on the dipstick and using the height, the transmission temperature, and the Transmission Fluid Graph, determine if the transmission oil level is correct.
8. Add or remove oil as necessary and recheck the oil level.
9. Once the oil level is correct, install the dipstick tube cap.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
change , compass , cvt , cvt fluid , patriot , service
No Bus Jeep Compass 08 sad day... codered911 Jeep Compass & Patriot Forum 8 08-31-2008 11:33 AM
Compass CRD - First 10,000km Service mdls4 Jeep Compass & Patriot Forum 3 12-13-2007 04:32 PM
Like my Jeep (Compass) x96mnn Jeep Compass & Patriot Forum 2 03-09-2007 08:41 AM
Jeep Compass andrew2516 Jeep Compass & Patriot Forum 128 08-04-2006 10:44 PM
Compass now Available on jeep.com table Jeep Compass & Patriot Forum 2 05-31-2006 11:58 AM
