08 Jeep Patriot AC Question - JeepForum.com
post #1 of 1 Old 06-17-2016, 10:25 AM Thread Starter
DarekSteele
For those more qualified and knowledgable, I have a quick question:
The last few weeks my AC Compressor has been making a squeaking sound when in idle and turned on (the sound stopped once gas was applied to get under power), and last night the noise stopped - replaced by the sound of a bearing running loose.
Since my AC Compressor no longer kicks on (it only blows regular air not cold) I am going under the assumption that the AC Compressor Clutch died finally, and I will have to replace it. I have a line on the clutch itself, but AZ and Adv is telling me that I'd have to swap out the entire unit because they don't get just the clutch.
[b]My question is - do you know if it is possible to replace ONLY the AC Clutch without having to replace the entire compressor?
Trying to hopefully save myself a few hundred dollars in replacing the piece myself here.
DarekSteele is offline
