07 Patriot All windows dead - JeepForum.com
post #1 of 4 Old 05-03-2012, 11:28 AM Thread Starter
super98lsc
Hey guys, I normally post in the WJ Forums but tomorrow I have a friend coming by with his wifes 2007 Patriot. He says the power windows (all of them) are dead stuck in the full up position. Fuses all check good. Just curious if these are controlled by a PCI bus like the WJ's or use a BCM etc, and if there is a common issue to look for. I am an electrical engineer among other things so wont be too hard to figure out with the Fluke, however figured I would ask the team first :-).
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #2 of 4 Old 05-07-2012, 07:51 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Once we have the correct code I can get in to more detail.
Set Condition: for either Diagnostic code B18BB (Low Current @ TIPM) or B191D (Over Current @ TIPM)
B18BB:
When the Totally Integrated Power Module (TIPM) senses a draw of between 65 and 100 amps for 80 ms., this code will set.
B191D:
When the Totally Integrated Power Module (TIPM) senses a draw of over 35 amps for over 120 ms. on the F981 Ignition Switch Output circuit, this code will set.
NOTE: The most probable cause for this DTC to set is that the driver held all four window switches down for an extended period of time thereby causing the high side driver, in the TIPM, to overheat and cut out. Once the high side driver is opened, it will remain open until the next key cycle. However, the code will remain as stored.
Possible Causes:
(F981) IGNITION SWITCH OUTPUT CIRCUIT SHORT TO GROUND
ALL FOUR WINDOW SWITCHES HELD DOWN FOR AN EXTENDED PERIOD OF TIME
DRIVER POWER WINDOW SWITCH
TOTALLY INTEGRATED POWER MODULE (TIPM)
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 4 Old 05-07-2012, 08:00 AM Thread Starter
super98lsc
Thanks for the help :-) . friend didnt make it by yet but might this eve. if it were coding due to overcurrent say from all switches held down etc.. Wouldnt it restore power after key cycle? He says all windows died and have remained dead leading me to think a short exists
post #4 of 4 Old 05-07-2012, 08:33 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
The code would stay in the computer but the windows should be active. It could be the TIPM (expensive) or just a short to ground (cheap but time consuming). I did have a window hang up on mine long ago because the track wasn't straight. That could have caused an over current had I left it run long enough.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
Air noise with rear windows down 09 patriot ratman91 Jeep Compass & Patriot Forum 7 09-01-2014 01:19 PM
Patriot needs some help firstresponder Jeep Compass & Patriot Forum 3 06-06-2012 09:49 AM
Windows in '09 Patriot: slow, stuck, frozen, etc tripleGmax Jeep Compass & Patriot Forum 9 01-23-2009 03:40 PM
getting patriot, can't decide color! (how is the patriot?) taseal Jeep Compass & Patriot Forum 20 02-08-2008 11:46 PM
Jeep Patriot w/foggy windows!! emo Jeep Compass & Patriot Forum 11 12-20-2007 05:22 PM
