Yay...heater not working... - JeepForum.com
post #1 of 18 Old 10-02-2015, 03:05 PM Thread Starter
robplumm
All vents blowing cold. Almost to the point of feeling like the A/C is running (it's 65 outside right now...).
I've been reading on the heater core issues (Mine's a 2012 JKUR), but don't see any deposits in the coolant reservoir (did have to add to it...basically empty).
Anything else to check before taking it in? I'm over 3 years...but under miles...so...warranty is gone.
Other note: CEL came on. Using key, it cycles through and says "Done", but no codes. Just...change engine oil (that's been coming on for a while now, though...they apparently set it for about 3500 miles, it still hasn't been 5000 miles since last change, which is the interval I usually go with).
robplumm is offline
post #2 of 18 Old 10-02-2015, 06:29 PM
Moezer
2015 JK Wrangler
Check ur thermo stat could need a replacement how many kms
Moezer is offline
post #3 of 18 Old 10-02-2015, 06:57 PM Thread Starter
robplumm
34500miles...so...55k km...give or take a few hundred.
Engine temp seems to be fine, though.
robplumm is offline
post #4 of 18 Old 10-02-2015, 09:04 PM
Moezer
2015 JK Wrangler
Does the heat be w hot air when u driving?
Moezer is offline
post #5 of 18 Old 10-02-2015, 10:18 PM Thread Starter
robplumm
Nope. Cold air at all times from all vents, defrost, floor.
Really hoping it's not the heater core
robplumm is offline
post #6 of 18 Old 10-02-2015, 10:33 PM
Moezer
2015 JK Wrangler
It'd either coolant or thermostat
Moezer is offline
post #7 of 18 Old 10-03-2015, 01:18 AM
christensent
2014 JK Wrangler
When you change to heat, do you hear the air flow sound change? You can definitely notice when the air flow is bypassed through the heater core, the air sound gets a bit louder at the same fan level. If you turn up the heat and hear absolutely no change (it takes a few seconds), then I'd say it's not your heater core, thermostat, etc. and is instead a computer problem or an issue with the servo that controls the air flow shutters.
christensent is offline
post #8 of 18 Old 10-03-2015, 08:11 AM
Tireguy
2009 JK Wrangler
You said you checked the reservoir (and had to fill it)...did you check the coolant level in the radiator? If its low, fill to proper level and recheck the heater function. If its full, run the engine to normal operating temp and turn the heater on. Are both the heater hoses warm? If one hose is warm/hot and the other is cold, you have a clog in the heater core. If they're both warm, the problem is somewhere else (air/heater control as mentioned above). If they're both cold, you have a cooling system problem (low coolant, air pocket in block, stuck thermostat).
Tireguy is offline
post #9 of 18 Old 10-03-2015, 09:06 AM Thread Starter
robplumm
Checked radiator and reservoir levels...both look good, no sludge in cap (whew). Checked heat on both hoses to core...both very hot as they should be.
To above...completely forgot about how it transitions to heat. We don't use heat many months out of the year here but yeah...there's no slight pause or blower change when you switch from cold to hot.
robplumm is offline
post #10 of 18 Old 10-04-2015, 02:12 PM Thread Starter
robplumm
Alrighty. Apparently I'm blind...but not finding the A/c to heat actuator? Or is it the same one that shifts to the different vents (Floor, defrost, etc...).
ETA: Played with the one right inside the glove box to the left. That one apparently controls vent selector only...no broken teeth on it.
robplumm is offline
post #11 of 18 Old 11-26-2015, 07:28 AM
rye5122
Heater core defect
I have the same issue - took it in to the dealer and it needs a new heater core and radiator flush. There is likely a manufacturer defect in the core, but they aren't admitting to it yet. The repair was quoted at $1,600. Luckily I bought an extended warranty and it should be covered. But I think Jeep needs to take care of this issue. My 2012 Wrangler has less than 40K miles, the heater shouldn't be going out!
rye5122 is offline
post #12 of 18 Old 11-26-2015, 11:28 AM
Shabbernigdo
They have had issues with sludge building up in them and clogin them up. I read about it a few years ago and decided to flush out my coolant about a year after i bought the jeep. i ended up flushing out a bunch of pink slime had the consistancy of snot for lack of a better term. It had also built up at the bottom of the resivor botle as well.
Shabbernigdo is offline
post #13 of 18 Old 11-27-2015, 09:49 AM
ccrane2299
I had a 2011 with the same issue. Dealer said it had block casting sand in the heater core. I took the radiator overflow bottle off before I took it to the dealer and it had some slimey white stuff in the bottom. The dealer flushed it and I had no more issues. You'd think with the new motor they would have fixed it?
ccrane2299 is offline
post #14 of 18 Old 04-04-2016, 07:40 PM
mrdeezus
So, I'm having same issue and inside under center dash both metal tubes are hot and I hear no sound coming out of vent when switching to heat. Ill check radiator but if that's good maybe actuator or thermostat? thanks!
mrdeezus is offline
post #15 of 18 Old 04-05-2016, 06:33 AM Thread Starter
robplumm
Mine was the actuator that's buried behind the center console...cheap part...not cheap fix if you don't want rip the console out yourself...
robplumm is offline
