X options: Set me straight - JeepForum.com
post #1 of 10 Old 11-19-2006, 02:19 PM Thread Starter
HellifIknow
X options: D44, Rear Locker, SB Disconnect?
I'm trying to figure out order options for an X. Most of my driving will be on paved road in-town (yeah, yeah, I know. Why get a jeep?) with regular trips up into the Blue Ridge mountains, forestry roads & limited access areas. Nothing intentionally crazy-technical but the weather has a way of destroying the FSRs up there.
I'm not going to tow anything. Not going to lift or up-size the tires. I don't need a Rubi and don't want 16 MPG. Does it make sense that I could put together an X w/3.21 gears, Dana 44, rear locker & swaybar disconnect (--last two are listed as late availability options for the X)?
If not, any suggestions on how to put it together? Thanks.
HellifIknow is offline
post #2 of 10 Old 11-19-2006, 03:04 PM
cliffmelanie1
I just bought a Sahara with the 6 speed,D44. It doesn't have lockers but that anti slip and roll mitigation work quite well. I get between 20 and 21mpg with mostly highway driving at 70mph. Not to bad if you ask me. It has the 3:21's and 32" tires.
05 Rubicon 31/2" RE lift, 305 70 16 Duratracs
cliffmelanie1 is offline
post #3 of 10 Old 11-19-2006, 04:19 PM Thread Starter
HellifIknow
Thanks. I guess it's doable. Anyone out there planning on getting/ordering sway bar disconnect on an X when it becomes available?
post #4 of 10 Old 11-19-2006, 05:14 PM
keithert
keithert's Avatar
I didn't realize the rear locker was an option on the X. That could be worth ordering one for instead of buying off the lot.
Current: 2016 Ram 1500 Sport - Past: 05 Wrangler LJ, 90 and 92 Trackers and 98 Wrangler SE
keithert is offline
post #5 of 10 Old 11-19-2006, 06:46 PM Thread Starter
HellifIknow
The brochure lists it as an X option, and it recently showed up on the jeep.com build page.
post #6 of 10 Old 11-19-2006, 08:19 PM
keithert
keithert's Avatar
Is it a true locker or just a limited slip option?
keithert is offline
post #7 of 10 Old 11-19-2006, 09:49 PM
shark3471
it is only a limited slip from what I have read.
I also read the sway bar disconnects will be available on the x after January and I plan on adding that option seeing as it is one of the coolest features. hopefully it is not super expensive. I have been unsure about getting a JK but after a few trips to see them in person I am completely sold. I am holding off buying one just so I can order the disconnects and so I can see if there are any serious bugs that show up in the first few months. I would love to have a rubi but I am stretching it in price as it is. I hope the dana 30 front in the Jk is at least as strong as the one in my YJ.
shark3471 is offline
post #8 of 10 Old 11-19-2006, 10:00 PM
wildzx
i am getting the x model 2 door and yes, i will put little big tires and take it off road but not allot.. too bad i can't afford the rubicon
wildzx is offline
post #9 of 10 Old 11-19-2006, 10:09 PM
SecondTJ
SecondTJ's Avatar
i dont see it on jeep.com,
id imagine its only a LSD, they will actually have a locker option? Only thing i dont like about the new lockers, is that they are open when not locked. On the TJs, when not locked it was limited slip
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #10 of 10 Old 11-20-2006, 06:51 AM Thread Starter
HellifIknow
Rear Locker an X Option?
My bad. It's the Limited Slip that's on jeep.com. I don't have the info here with me at work, and "Trac-Lok" and "Tru-Lok" are confusing the matter, but the brochure says that Trac-L limited slip is an option on the X. Tru-L front/rear electronic disconnects are standard on the Rubi, & Tru-L rear electronic disconnect is an option on the X.
I'm reading this to mean that a rear locker is available as an X option.
Does this sound right?
Straight 30W Oil CheapSunglasses YJ Wrangler Technical Forum 7 10-10-2008 06:13 PM
4.0L straight six in Jk sportman JK Wrangler Technical Forum 29 09-25-2008 06:13 AM
Cant keep her straight! Rush YJ Wrangler Technical Forum 16 05-06-2006 04:09 AM
TJ won't go straight madmax TJ Wrangler Technical Forum 5 09-29-2005 09:18 PM
Straight 40 oil jess YJ Wrangler Technical Forum 1 06-21-2003 12:31 PM
