WTF can't get new brake pads over new rotors... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > WTF can't get new brake pads over new rotors...
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 04-28-2011, 01:17 PM   #1
RedArrow10
I've never had this problem with my 05 TJ when replacing the front rotors and pads. But, I can't no matter what position the caliper is in, get te new brake pads to fit over the new brake rotor. Both NAPA brand OE replacement and I verified the part numbers.... Any tricks to the JK versus the TJ when trying to replace new pads & rotors?
"There is nothing so likely to produce peace as to be well prepared to meet the enemy."
105th Cavalry - OIF 07/08 - 101st Airborne
RedArrow10 is offline   Reply With Quote Quick reply to this message
Unread 04-28-2011, 01:28 PM   #2
JkFuriousd
2010 JK Wrangler
Did you check to make sure the calipers aren't pushed out from having older pads on them?
2010 Rubicon 2dr
JkFuriousd is offline   Reply With Quote Quick reply to this message
Unread 04-28-2011, 02:05 PM   #3
aznjeep
aznjeep's Avatar
2014 WK
x2 for JkFuriousd.. although, I'm assuming that he's following the same procedure as the TJ, where we push the piston back into the caliper. I used the old pad (on my TJ), flip it, then a C-clamp to press it back in as evenly as possible... I've got less than 12k miles on the JK, and not due for a brake job anytime soon based on what I saw the last time I took my wheels off...
Edit: I'm also wondering if the parts store's reference number is correct for "factory" specs.. perhaps the rotors are too thick/wide?
-Ken
'96 XJ Sport
'14 WK2 Overland EcoDiesel
'13 JKUR 10A (sold) Build Thread
'10 JKUR (sold) Build Thread
'99 TJ (sold)
aznjeep is offline   Reply With Quote Quick reply to this message
Unread 04-28-2011, 03:51 PM   #4
RedArrow10
Tried the c-clamp and it worked. The piston went in a lot more than I thought it would. Front brakes are done! Now if I could only get the f*$&ing rotor off the back...... This was suppose to be an easy job and I should have been done two hours ago!
Unread 04-28-2011, 04:25 PM   #5
RedArrow10
I obviously don't have a big enough hammer. So what is the trick getting the rotors past the parking brake shoes.
Unread 04-28-2011, 04:27 PM   #6
BriansCJ
1994 XJ Cherokee
You should be able to adjust them in a little bit so the rotor will just slide right off, I think.
5 Speed XJ Build - Daily Driver & Weekend Wheeler
1978 CJ5 Resto, w/ heavy mods - Slow
BriansCJ is offline   Reply With Quote Quick reply to this message
Unread 04-28-2011, 04:52 PM   #7
spedly
2011 JK Wrangler
Your parking brake isn't on right? They should wiggle off if you work them side to side.
Poser Jeep.
spedly is offline   Reply With Quote Quick reply to this message
Unread 04-28-2011, 05:45 PM   #8
Mac71
I tend to smack the rotors initially on their face, between the studs to jar them a little. Then placing a prybar behind the rotor to give the rotor a little preload, and tapping the side of the "top hat", pry the rotor off. This tends to walk the rotor's rust ridge past the parking shoes. This can be a real pain so good luck!
Mac71 is offline   Reply With Quote Quick reply to this message
Unread 04-28-2011, 08:33 PM   #9
aznjeep
aznjeep's Avatar
2014 WK
Someone just posted this on another thread.. maybe it will help?
http://project-jk.com/jeep-jk-write-...ad-replacement
-Ken
'96 XJ Sport
'99 TJ (sold)
Unread 04-28-2011, 09:03 PM   #10
Warlord2
Ive had 2 rotors get stuck before on me, both times I ended up using a harbor freight wheel puller and a big a$$ hammer. I clamped a wood 2x4 using some clamps onto the rotor and smacked it with a hammer tell it broke free.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline   Reply With Quote Quick reply to this message
Unread 04-29-2011, 07:23 PM   #11
BeerMonkeY
your ebrake is off right?
'92 YJ
'98 ZJ 5.9
'13 WK2 HEMI
BeerMonkeY is offline   Reply With Quote Quick reply to this message
Unread 04-29-2011, 07:26 PM   #12
Skytard
Didn't read any posts but you need to put the pad that sits on the piston in the caliper and put a c-clamp over it and tighten to compress the piston. I take it you have never done a bj before? lol
Poor college student.
Skytard is offline   Reply With Quote Quick reply to this message
Unread 04-29-2011, 07:27 PM   #13
Skytard
Sorry, should have read. to get the rear off, tap with a hammer all around the edges while prying it and it should come off.
