WTF can't get new brake pads over new rotors... - JeepForum.com
post #1 of 13 Old 04-28-2011, 12:17 PM Thread Starter
RedArrow10
I've never had this problem with my 05 TJ when replacing the front rotors and pads. But, I can't no matter what position the caliper is in, get te new brake pads to fit over the new brake rotor. Both NAPA brand OE replacement and I verified the part numbers.... Any tricks to the JK versus the TJ when trying to replace new pads & rotors?
"There is nothing so likely to produce peace as to be well prepared to meet the enemy."
105th Cavalry - OIF 07/08 - 101st Airborne
RedArrow10 is offline
post #2 of 13 Old 04-28-2011, 12:28 PM
JkFuriousd
2010 JK Wrangler
Did you check to make sure the calipers aren't pushed out from having older pads on them?
2010 Rubicon 2dr
JkFuriousd is offline
post #3 of 13 Old 04-28-2011, 01:05 PM
aznjeep
2014 WK
x2 for JkFuriousd.. although, I'm assuming that he's following the same procedure as the TJ, where we push the piston back into the caliper. I used the old pad (on my TJ), flip it, then a C-clamp to press it back in as evenly as possible... I've got less than 12k miles on the JK, and not due for a brake job anytime soon based on what I saw the last time I took my wheels off...
Edit: I'm also wondering if the parts store's reference number is correct for "factory" specs.. perhaps the rotors are too thick/wide?
-Ken
'96 XJ Sport
'14 WK2 Overland EcoDiesel
'13 JKUR 10A (sold)
'10 JKUR (sold)
'99 TJ (sold)
aznjeep is offline
post #4 of 13 Old 04-28-2011, 02:51 PM Thread Starter
RedArrow10
Tried the c-clamp and it worked. The piston went in a lot more than I thought it would. Front brakes are done! Now if I could only get the f*$&ing rotor off the back...... This was suppose to be an easy job and I should have been done two hours ago!
post #5 of 13 Old 04-28-2011, 03:25 PM Thread Starter
RedArrow10
I obviously don't have a big enough hammer. So what is the trick getting the rotors past the parking brake shoes.
post #6 of 13 Old 04-28-2011, 03:27 PM
BriansCJ
1994 XJ Cherokee
You should be able to adjust them in a little bit so the rotor will just slide right off, I think.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #7 of 13 Old 04-28-2011, 03:52 PM
spedly
2011 JK Wrangler
Your parking brake isn't on right? They should wiggle off if you work them side to side.
Poser Jeep.
spedly is offline
post #8 of 13 Old 04-28-2011, 04:45 PM
Mac71
I tend to smack the rotors initially on their face, between the studs to jar them a little. Then placing a prybar behind the rotor to give the rotor a little preload, and tapping the side of the "top hat", pry the rotor off. This tends to walk the rotor's rust ridge past the parking shoes. This can be a real pain so good luck!
Mac71 is offline
post #9 of 13 Old 04-28-2011, 07:33 PM
aznjeep
2014 WK
Someone just posted this on another thread.. maybe it will help?
http://project-jk.com/jeep-jk-write-...ad-replacement
-Ken
'96 XJ Sport
'13 JKUR 10A (sold)
'10 JKUR (sold)
'99 TJ (sold)
aznjeep is offline
post #10 of 13 Old 04-28-2011, 08:03 PM
Warlord2
Ive had 2 rotors get stuck before on me, both times I ended up using a harbor freight wheel puller and a big a$$ hammer. I clamped a wood 2x4 using some clamps onto the rotor and smacked it with a hammer tell it broke free.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #11 of 13 Old 04-29-2011, 06:23 PM
BeerMonkeY
your ebrake is off right?
'92 YJ
'98 ZJ 5.9
'13 WK2 HEMI
BeerMonkeY is offline
post #12 of 13 Old 04-29-2011, 06:26 PM
Skytard
Didn't read any posts but you need to put the pad that sits on the piston in the caliper and put a c-clamp over it and tighten to compress the piston. I take it you have never done a bj before? lol
Poor college student.
Skytard is offline
post #13 of 13 Old 04-29-2011, 06:27 PM
Skytard
Sorry, should have read. to get the rear off, tap with a hammer all around the edges while prying it and it should come off.
Skytard is offline
new brake pads, rotors turned, pulls to right GMC7000 Wrangler General Discussion 5 05-03-2009 02:45 PM
Recommended Brake Rotors & Pads? cvd TJ Wrangler Technical Forum 35 08-19-2008 10:07 PM
I just need answers - hopefully not a fight?! (Brake pads and rotors) BlueJ TJ Wrangler Technical Forum 31 01-17-2008 09:36 AM
Need help with replacement brake pads and rotors bshwckr TJ Wrangler Technical Forum 10 07-26-2006 12:45 AM
Brake Pads And Rotors WR4NGLER TJ Wrangler Technical Forum 50 07-23-2004 05:31 PM
