Writeup for swapping springs - Page 2 - JeepForum.com
post #16 of 20 Old 02-12-2010, 12:08 PM
tricked919
Originally Posted by computerguy View Post
Ok...........if I have no tags on the springs then how do I know which is which? Are they stamped anywhere? I really appreciate everyone's input!
you don't ...and finding out is probably WAY more work than its worth.
Go buy a set of proven OME coils for $150.
'07 JK 2dr Sahara - auto w/ 4.10's and rear locker. 2" OME HD coil lift, BDS shocks, and 1" body-lift. 34" Hankook RT09 MT's on 16" AEV Bridgers. ARB diff covers, Warn bumpers, Warn 9K winch, a couple Hella lights ...and a WORTHLESS AirRaid CAI.
tricked919 is offline
post #17 of 20 Old 02-12-2010, 12:17 PM
rerard
Just finished... super easy, other than the lugs there are 2 other bolts per corner which use the same socket and are very easy to reach. I'll post some pics tonight in the JK pic sticky, 33s look perf with the unlimited springs IMO. I may actually hold off on trimming the bumper/flares.
rerard is offline
post #18 of 20 Old 02-12-2010, 12:34 PM
dirtyjpwrangler
awesome. One question - did you use a torque wrench? I have all the tools except for that one...
'08 X, Jeep Green, 6 speed, 32" BFG MT's, power options, rubi rock rails, front grab handles, soft top all year round ...oh yea and dirt.
dirtyjpwrangler is offline
post #19 of 20 Old 02-12-2010, 12:38 PM
rerard
No I didn't.... I doubt it matters for the shocks or the sway bar links, and your ok with the lugs as long as you are careful not to over tighten them.
rerard is offline
post #20 of 20 Old 02-12-2010, 01:23 PM
ncb
Make sure the lower shock mount bolts/nuts are tight. On my Rubi, the shock mount holes are slightly larger than the bolts. On the test drive after installing the lift I had a clunk on small bumps/crack. I then torqued all hardware to specs (like I should have to begin with) and the clunk was gone. The bolts had enough movement to make a nice clunking sound.
ncb is offline
Swapping out springs? IH8ROADZ TJ Wrangler Technical Forum 12 10-30-2008 09:59 PM
swapping to 3.5 inch springs? deryk111 TJ Wrangler Technical Forum 16 10-12-2008 10:14 PM
springs, axles, and swapping? jmathis3 YJ Wrangler Technical Forum 8 02-14-2008 10:35 AM
Swapping my Pro-Comp springs for RE's Austin_YJ YJ Wrangler Technical Forum 6 09-21-2006 09:10 AM
Swapping front Coil Springs alt13 TJ Wrangler Technical Forum 5 06-13-2006 09:10 AM
