Writeup for swapping springs - JeepForum.com
post #1 of 20 Old 02-11-2010, 06:36 AM Thread Starter
computerguy
Are there any good writeups for swapping springs? I just picked up a set of Rubicon springs and shocks to install into my X Unlimited. I assume this should be pretty easy, but would like some instructions before tackling it.
computerguy is offline
post #2 of 20 Old 02-11-2010, 06:50 AM
DavidJK
Take a look at these lift instructions.
http://www.teraflex.biz/?wpv_file_id...e04001ecdbf420
DavidJK is offline
post #3 of 20 Old 02-11-2010, 06:53 AM Thread Starter
computerguy
Thanks! I tried that link but it does not work.
post #4 of 20 Old 02-11-2010, 06:58 AM
GOREBS
If you are going to do that you may as well do a BB. I did the RC 2.5 BB and added some Rubicon shocks i got for dirt cheap. I already had the heavier springs because ive got the tow pkg.
GO REBS
GOREBS is offline
post #5 of 20 Old 02-11-2010, 07:17 AM
tricked919
This is a cake-walk job.
- lift Jeep by frame and put on jackstands, (if you can't get it high, take your wheels off)
- put a jack under the axle and raise it till it just supports the weight of the axle.
- remove bolts for sway bar (lower) and lower shock bolts
- slowly lower the jack holding up the axle. It will drop low enough that the springs should fall out.
If you have a spring compressor, its a bonus - ESPECIALLY for tall springs. If you have an auto, you might have to remove the tranny skid plate or else it will catch the front drive shaft, preventing it from lowering far enough (again, spring compressor is nice). I was able to put OME 4dr HD coils in mine without removing the skid plate or the track bar. I used a compressor though, just because I had it. Not sure if I needed it. You can rent them REALLY cheap.
Total job was just under 2 hours for all 4 springs with the right tools. My coils replaced a BB, so I already had shocks on.
'07 JK 2dr Sahara - auto w/ 4.10's and rear locker. 2" OME HD coil lift, BDS shocks, and 1" body-lift. 34" Hankook RT09 MT's on 16" AEV Bridgers. ARB diff covers, Warn bumpers, Warn 9K winch, a couple Hella lights ...and a WORTHLESS AirRaid CAI.
tricked919 is offline
post #6 of 20 Old 02-11-2010, 07:40 AM
DavidJK
Sorry about that. Just go to www.teraflex.biz and look at the install instructions for a 2.5" coil lift. It will walk you right through swapping springs and even has some pics.
DavidJK is offline
post #7 of 20 Old 02-11-2010, 04:43 PM
Blu-Jacket
2009 JK Wrangler
It's very straight forward to R&R the springs and shocks. As mentioned above, you will need to pay attention to the front driveshaft and the brake lines when you lower the axle.
Blu-Jacket is offline
post #8 of 20 Old 02-12-2010, 06:14 AM
daggo66
2009 JK Wrangler
Before you make the switch, take a look at the tags on the new springs and your current springs. If the last 2 numbers on the new springs are not higher numbers than your current springs, you are wasting your time. The front springs should be 2 different numbers with the lower number going on the driver's side.
Rubicon springs are not necessarily stiffer. An unlimited with tow package has the stiffest rated springs. The is a great write up somewhere on JK Owners.
Tom
daggo66 is offline
post #9 of 20 Old 02-12-2010, 07:49 AM Thread Starter
computerguy
The springs do not have tags on them. They came off a 2010 Unlimited Rubicon with a hard top and tow package. So I need to be careful which front spring goes on the drivers side?
post #10 of 20 Old 02-12-2010, 08:03 AM
MattJK09
2009 JK Wrangler
No the front doesn't matter and I'm not sure the rear does either.....
09 X 23S Flame Red 2door, tinted, Black Rock 997's, BFG 32" MT's, grab handles, RR XHD front bumper,BW trail armor,4door springs up front, KC's
MattJK09 is offline
post #11 of 20 Old 02-12-2010, 10:08 AM
rerard
I just finished swapping one front spring, took me about 20 minutes. I went from 13's to 16's and unfortunately it only gave me about 1/2" of lift (I should have done better research). Both front springs had the same numbers. I'm only putting on 33's so I don't need much lift anyway, plus I am planning to trim the bumper tomorrow and maybe the fenders if I have time.
I'm working from home today so I'll do the other springs throughout the day and throw up some pics when I'm done.
rerard is offline
post #12 of 20 Old 02-12-2010, 10:09 AM
dirtyjpwrangler
This is a pretty awesome write up.
Project-JK.com - Jeep JK Wrangler Resource TeraFlex Jeep JK Wrangler 2.5″ Budget Boost Lift Installation Write-Up
I have a feeling I might be doing this BB someday
'08 X, Jeep Green, 6 speed, 32" BFG MT's, power options, rubi rock rails, front grab handles, soft top all year round ...oh yea and dirt.
dirtyjpwrangler is offline
post #13 of 20 Old 02-12-2010, 10:10 AM Thread Starter
computerguy
Thanks! I appreciate it!
post #14 of 20 Old 02-12-2010, 11:41 AM
daggo66
2009 JK Wrangler
Actually it does. The higher rated spring goes on the passenger side to compensate for the fuel tank.
Tom
daggo66 is offline
post #15 of 20 Old 02-12-2010, 11:53 AM Thread Starter
computerguy
Ok...........if I have no tags on the springs then how do I know which is which? Are they stamped anywhere? I really appreciate everyone's input!
Swapping out springs? IH8ROADZ TJ Wrangler Technical Forum 12 10-30-2008 09:59 PM
swapping to 3.5 inch springs? deryk111 TJ Wrangler Technical Forum 16 10-12-2008 10:14 PM
springs, axles, and swapping? jmathis3 YJ Wrangler Technical Forum 8 02-14-2008 10:35 AM
Swapping my Pro-Comp springs for RE's Austin_YJ YJ Wrangler Technical Forum 6 09-21-2006 09:10 AM
Swapping front Coil Springs alt13 TJ Wrangler Technical Forum 5 06-13-2006 09:10 AM
