Wrangler unlimited water leak SOLVED!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Wrangler unlimited water leak SOLVED!!
Offset Tie Rod Kit From RuffStuff!Ruffstuff Axle Simple Swap Kit!ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail
Unread 08-11-2012, 09:22 PM   #1
bill12920
2011 JK Wrangler
Hope this helps some others out there. After months and months of dealing with water leaks every time it rains, many trips to the dealer, new header, new top weatherstripping, etc. etc, to no avail, I took matters into my own hands and solved the problem.
The water (and not a small amount) would always be found dribbling in around the bottom of the door jambs (both front doors). I always found it an odd design feature that the door jamb body metal curved inward without any lip or gutter to turn the water toward the outside. I surmised that, if any water got past the weather stripping somewhere, it could potentially just spill over to the interior so I added water soluble paint along the door jamb and then closed it up and waited for the rain. After the storm passed, I opened the door and saw the trail of water, the path that it followed, etc.
Basically, the weatherstripping doesn't fit tightly against the windshield/body joint and any water that is flowing down from the top can make a turn inward at that point and slide down along the door jamb until it reaches the bottom and then follows the metal that is curved inward and spills out onto the front floor.
The solution is to add a big blob of silicone at the windshield/body joint and then close the door and leave it closed until the silicone dries. It will conform to the shape of the weather stripping and result in a nice, tight seal that prevents the water from running down the length of the door jamb. There have been several BIG rains since installing this fix and the jeep is completely and finally dry.
bill12920 is offline   Reply With Quote
Unread 08-13-2012, 07:37 PM   #2
meon2wheels
2011 JK Wrangler
Always a good feeling when problems get solved. Thanks for sharing. i keep an eye out for shifted seals. Black RTV would hide the fix a little better.
meon2wheels is offline   Reply With Quote
Unread 08-13-2012, 11:45 PM   #3
1222
Make mine a Jeep!
1222's Avatar
Nice troubleshooting and fix you did there and thanks for posting it.
Also, to the forum.
1222 is offline   Reply With Quote
Unread 08-20-2012, 12:44 PM   #4
cbene
Jeep Leak Fix
When you put the silicone in and close the door does the door stick shut when it dry's?
I have been battling leaking for the past 4 years with no resolution from Jeep.
Thanks.
cbene is offline   Reply With Quote
Unread 08-22-2012, 02:28 PM   #5
jwmbishop
2011 JK Wrangler
It looks like he allowed the bead to dry with the door open.
However you CAN make a seal by putting down the silcone then covering it with saran wrap. Close the door to the first click (this will allow the silcone to remain "overfilled" so that when dry and closing all the way there is still pressure being applied to the now dry seal). When its all dry just pull the saran wrap off.
J Wm Bishop EA, ASADE
I'm not always rude or sarcastic, I do sleep sometimes.
jwmbishop is offline   Reply With Quote
Unread 08-22-2012, 10:03 PM   #6
jksmith93
I tried this to no avail but I didn't use that much silicone. I'll give it another shot sometime soon. Fingers crossed!
jksmith93 is offline   Reply With Quote
Unread 12-10-2013, 09:10 AM   #7
Debest21
2010 JK Wrangler
Water leaks
Thanks for da help
Debest21 is offline   Reply With Quote
Unread 12-10-2013, 09:23 AM   #8
Debest21
2010 JK Wrangler
That means that da water could in da jeep floors
Unread 12-10-2013, 09:24 AM   #9
Debest21
2010 JK Wrangler
Da water could end in da jeep floors does it because are kind of souk
