Which Wrangler to buy? - Page 2 - JeepForum.com
post #16 of 40 Old 12-02-2010, 08:08 PM
Charles
2017 WK
The 07's didn't have a removable tray in the center console. They didn't put mirrors in the visors until 10. The new visors are $120.
Rubicon or not?:
The first benefit the Rubicon has over other models are the 4.10 gears. This lower gear ratio (inside the deferential) allows for bigger tires with less need for regearing and also provides a better gear ratio for trail driving with stock Rubicon tires. Some Jeepers will argue that you need to regear, even with 4.10, gears once you get to 35 inch tires. It is recommended that you get your tires and THEN decide if you want to regear.
Another difference between the Rubicon and the other models is the 4:1 transfer case. For sand the 4:1 transfer case is not needed but it is no disadvantage either. Bogging in soft sand with the and then needing to downshift can contribute to getting stuck, the 4:1 transfer case will keep the revs up. Arguably this could also be accomplished by selecting and staying in a lower gear with the 2.72:1transfer case (that is the transfer case found on other Jeep models). The 4:1 transfer case probably provides the biggest benefit when climbing steep inclines and traversing obstacles, especially in a six speed. The torque is so high the vehicle is virtually impossible to stall.
Another benefit of the Rubicon is the front D44 front axle. This axle is the same axle found on the rear of the Rubicon and the rear of other Jeeps (other Jeeps have a Dana 30 in the front). The Dana 44 axle provides more strength when torque is applied to the wheels (i.e. hard acceleration in deep mud or snow) and when Jeeper decides to put on larger tires which, in turn, will amplify the amount of stress applied to the axle when torque is applied, especially when the lockers are applied.
The lockers are the most expensive and perhaps best feature of the Rubicon. I will explain what lockers do; If you were to take a regular four wheel drive vehicle (which has open differentials) and get it stuck with one side of the vehicle in deep snow and ice, and the other side on blacktop and try to accelerate, the wheels in the snow and ice would spin and the vehicle would remain stuck. When you turn on the lockers, (essentially eliminating the differential and locking both sides of the axle together) the torque will be forced to all four wheels providing torque to the wheels on the blacktop which would free the vehicle. So, a four wheel drive vehicle without lockers is really two wheel drive because the wheel with LESS traction on each axle will spin until the locker is applied.
Other Jeep models have “Brake Lock Differential” (BDL) which is a kind of locker substitute. It works by applying the brake to the spinning wheel to force torque, through the differential, to the wheel with traction. This IS NOT the same as a locker. Over time the brakes will over heat. Additionally, BDL is reactionary. There has to be wheel spin for it to activate. By then you’re already behind the traction curve. I am going to end the BDL discussion there. If you’re reading this and want more discussion on BDL post a thread and we can discuss it.
The next feature that will be discussed is the electronic sway bar disconnect. Having a sway bar disconnect allows for more travel of the axle when the vehicle is in situations where the ground is uneven. This is called “articulation”. Sway bar disconnects can be added later but they will be manual disconnects which can be difficult to work with and are generally inconvenient . The convenience of electronic sway bar disconnects can be compared to in cab four wheel drive engagement. In the past one had to get out and lock the hubs to get four wheel drive, that is unthinkable in this era of 4X4. It can be said now that “in the past one had to get out to disconnect the sway bar”. It’s a great feature.
Another feature of the Rubicon is the larger tires. The larger tire gets your differential off the ground. While a larger lift gets your body higher off the ground, there is only one way to raise the axles and differentials, and that is a larger tire.
Finally, the Rubicon has rock rails that protect the lower body near the doors. They provide side and undercarriage protection in that region. They are one of the most important off road additions since it pretty easy to damage that part of the body if you come down on an obstacle or turn too tight near an obstacle.
Hopefully this write up has helped you decide if the Rubicon is right for you!
Charles is offline
post #17 of 40 Old 12-02-2010, 08:10 PM
Charles
2017 WK
Originally Posted by LIMETIME View Post
Buy the newest X/Sport you can afford. For beach driving, a Rubicon will be a waste of money.
Is buying a Lamborghini Murcielago a waste for everything other than track driving?
Charles is offline
post #18 of 40 Old 12-02-2010, 08:47 PM
JFD140
2011 JK Wrangler
Its kind of a waste on every level possible lol.
You could turn a rubicon into an actual monster truck and still have 300000 to play with for that cash.
Side note- not to thread steal but is it a waste to look into the rubicon if I will rarely go wheeling? ( I have never been before but wanna get into it) I just want big tires and lift cuz its what I like.
JFD140 is offline
post #19 of 40 Old 12-02-2010, 08:52 PM
Charles
2017 WK
No, the sticker (you know what I mean) alone ensures an easier re-sale, and if I've ever read a forum post, there are constantly guys who wish they would have just done the damn thing because they found a trail by accident and are instantly hooked on wheeling and are stuck with a non-Rubicon. If you know 100% that you'll never get into wheeling then, well, you're probably wrong :-)
It's a money thing too. Those things aren't cheap, if your children will go unfed for months while you put money together then you have to make that call, but, if you have the means, then by all means.
Charles is offline
post #20 of 40 Old 12-02-2010, 08:53 PM
Green98TJ
2010 JK Wrangler
When I bought my 2010 I could have got a Rubi it was the same money as my Mountain edition but had no power options and was a straight drive I had to think about how I use my daily driver and how much I would be off roading and decided I would use the power options and much rather have the auto for my city stop and go driving than the Rubi's off road capabilities not saying you can't get a Rubi with all the bells and whistles but it will cost ya.
But you wouldn't use a Bazooka dove hunting....or maybe you would. LOL
Contact Jason at KOR for all your Jeep Needs.
2010 JK Mountain
Green98TJ is offline
post #21 of 40 Old 12-02-2010, 08:58 PM
Charles
2017 WK
OH, I would!
Charles is offline
post #22 of 40 Old 12-02-2010, 09:12 PM
JFD140
2011 JK Wrangler
OH, I would!
2nd.
Are all rubis manual?
I work in new york city...
JFD140 is offline
post #23 of 40 Old 12-02-2010, 09:19 PM
Green98TJ
2010 JK Wrangler
2nd.
No, You can get a Auto.
2010 JK Mountain
post #24 of 40 Old 12-02-2010, 09:26 PM
Charles
2017 WK
Friend, you need a $500 Honda to drive to work in.
Charles is offline
post #25 of 40 Old 12-02-2010, 09:27 PM
JFD140
2011 JK Wrangler
bite your tongue!
I have a private parking lot. She will be safe.
JFD140 is offline
post #26 of 40 Old 12-02-2010, 09:33 PM
Charles
2017 WK
bite your tongue!
I read an article once that people would have their oil changed at Jiffy Lube or similar everyday rather than pay for parking in NYC. It was cheaper just to let it sit at the oil change place all day than pay for parking.
I've been to NYC and I can't imagine driving a my GIGANTIC Jeep there.
Charles is offline
post #27 of 40 Old 12-02-2010, 09:45 PM
JFD140
2011 JK Wrangler
I work for FDNY we have a nice private barbed wire fenced lot at the station.
JFD140 is offline
post #28 of 40 Old 12-02-2010, 09:49 PM
Mol
Disclaimer: I'm Polish
Mol's Avatar
Hahaha, hadn't heard that one!
Good write-up on the Rubi Mike
Mol is offline
post #29 of 40 Old 12-02-2010, 09:56 PM
Charles
2017 WK
Thanks!
Charles is offline
post #30 of 40 Old 12-03-2010, 01:59 PM
OregonVette
yeah, whatever... If you plan on taking an X, Sport or Sahara in the gravel, dirt or even grass 4 inches high it will get stuck & explode because it was clearly not inteded for off road use. Duh, that's simple. We all know that the rubicon is an actual off road vehicle and those of us non-rubi owners are all mall crawlers, dating our sisters and have a 9th grade education, yeah, yep. that's right!
I had to call my neighbor girl who owns a rubi (which has NEVER seen dirt) to get me out of this bind (note the back tire is in 3" of gravel) :
then, I got stuck trying to climb this hill, jumped out, flagged a rubicon owner & he towed me to safety!
okay, thick with sarcasm over
Originally Posted by smcutter View Post
It's hard to give you good advice at this point. It's almost like you're saying, "I want to have sex, but don't want to get her pregnant. I can't afford condoms, so for now I just want to use Saran Wrap. What brand would you recommend?"
OregonVette is offline
Will hardtop and doors from 1990 Wrangler fit on 1992 Wrangler? jacksprat1 YJ Wrangler Technical Forum 5 09-23-2010 08:22 PM
Goodyear Wrangler Duratrac on a wrangler question ArrizX Wrangler General Discussion 23 11-26-2009 06:48 PM
Turn a 1997 Wrangler into a 2006 Wrangler MeSoDumm TJ Wrangler Technical Forum 14 06-25-2008 09:24 PM
Will a 1989 Wrangler Full steel door/hard top fit on a 1995 Wrangler alandchris YJ Wrangler Technical Forum 2 03-13-2007 03:51 PM
Using a Soft-Top From a 2000 Wrangler on a 1998 Wrangler? Nighthawk TJ Wrangler Technical Forum 3 06-05-2002 05:02 PM
