Working on a friends jku and need help. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Working on a friends jku and need help.
Great prices on seating!--Oconee Off-RoadTJ 5.25" Speaker Adapters - NalinMFGTJ, YJ & LJ Drop Down Tail Gate Conversion Kit
Unread 06-26-2014, 10:33 AM   #1
99goldxj
Doing some minor fixes, friend is a truck driver and is going off road for first time seven months next month. I noticed a headlight was not looking right. Thought it just needed aimed, it turned out to be loose. After investigating today, I figured out the part the adjuster screws sit in is broke (plastic black piece). Anyone know what that is called that I can fix this? I am doing this as a favor without asking because he has let my wife and myself drive his jku offload before. I have until July 5th until he will be wheeling it.
"Last time I considered busting through a snow bank I drove around it first. Good thing I did. It was a car"
"but yeah i guess if i did it all over, i would have hit her."
[QUOTE=99XJBeast;11291646]its running like a raped ape on steroids.[/QUOTE]
1999 XJ. 235 Big O AT's. Clear bumper and side markers. 6.5 inch speakers in rear. Soon to be all LED bulbs (need turn signal flasher and led bulbs and gauge lights).
99goldxj is offline   Reply With Quote
Unread 06-26-2014, 10:58 AM   #2
ncb
Here's a link with the adjuster-
http://www.4wd.com/Jeep-Exterior-Par...FUNgMgodqjUANg
http://www.4wheelparts.com/Exterior-...FUNgMgodqjUANg
ncb is offline   Reply With Quote
Unread 06-26-2014, 11:16 AM   #3
99goldxj
The screw itself is fine, the plastic piece is broke.
Unread 06-26-2014, 11:16 AM   #4
jwmbishop
2011 JK Wrangler
I would bet its a dealer item... unless the part linked above has both the screw and the plastic part (like older cars sets do). Call dealer and get the part number!
J Wm Bishop EA, ASADE
When I said that I was acceptably sane I may have exaggerated slightly.
jwmbishop is offline   Reply With Quote
Unread 06-26-2014, 03:48 PM   #5
PhatBasturd
PhatBasturd's Avatar
1976 CJ7
Google part #: 55078148AC
Should get you in the ball park.
PhatBasturd is offline   Reply With Quote
