Won't take gas - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Won't take gas
Time To Save On Yukon Lockers!Rough Country Lift Kits and Parts!Ruffstuff 10 year sale
Unread 12-10-2011, 09:04 PM   #1
DAYJ
Won't take gas
Any one ever hear of a 2010 not taking gas? I pull up to the pump and when i fill it up it get about a gallon in and it cuts the pump off, tried it at several pumps and sever nozzle positions. So far my one and only local dealer has changed a gas tank... What other things that could be causing this?
New- 2013 Commando Green Rubicon
Old-2010 Flame Red Rubicon Unlimited
Utah Jeep Crew Member #47
Cheyenne Trail Junkie
ROADS!? Where we're going, we don't need roads... (Doc)
DAYJ is online now   Reply With Quote Quick reply to this message
Unread 12-11-2011, 05:46 AM   #2
Jos360
2010 JK Wrangler
I have it every now and then. As far as I understand, the hose from the filler cap to the gas tank has a check valve in it, which allows you to fill up the tank and allows air to bleed from the tank, but unables you to syphon gas out of it. Maybe you should look into that, because if it doesn't properly open, the tank pistol will think the tank is full because the gas spits back at it and shuts off.
2010 Jeep JK Unlimited. Sahara, 6spd manual, Deep Water Blue.
Jos360 is offline   Reply With Quote Quick reply to this message
Unread 12-11-2011, 10:24 AM   #3
222Doc
Sounds like they did not replace the tank. I can not see this happening two times, and with a new tank? something sound fishy. How old li the "new tank"?
222Doc is online now   Reply With Quote Quick reply to this message
Unread 12-11-2011, 10:37 AM   #4
DAYJ
well i looked at the new tank when they installed it, it looked pretty dang new... but i dont exactly trust the dealer i have to go to because they orig ordered a new hose to go from the filler cap to the tank and ordered the wrong one, but just happened to have a tank layin around so they changed it...
Unread 12-11-2011, 10:48 AM   #5
Mol
Disclaimer: I'm Polish
Mol's Avatar
Mine does it on occasion - annoying as hell. I usually just keep going at it, repositioning the nozzle, and it will eventually go. Does yours do this every time you try to fill up?
Mol is offline   Reply With Quote Quick reply to this message
Unread 12-11-2011, 11:15 AM   #6
sam187st
2011 JK Wrangler
mine does it to sometimes. i think it has something to do with the fumes.
sam187st is offline   Reply With Quote Quick reply to this message
Unread 12-11-2011, 11:20 AM   #7
jmb6420
Engr. & Mechanic 08 Rubi
jmb6420's Avatar
Mine did it, but once the dealer replaced the tank, it's never happened again. The dealer had to order the tank, they didn't keep them in stock. I asked if they could just replace the fill hose and was told "no" the fix is to replace tank and fill hose, replacing the hose will not fix the problem.
Mike
08 Rubicon Red Jeep Club #629
"You can't fix stupid" Ron White
°ɹǝʌo ǝɯ dıןɟ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
jmb6420 is offline   Reply With Quote Quick reply to this message
Unread 12-11-2011, 12:16 PM   #8
1222
Make mine a Jeep!
1222's Avatar
Originally Posted by DAYJ View Post
...they orig ordered a new hose to go from the filler cap to the tank and ordered the wrong one, but just happened to have a tank layin around so they changed it...
Sounds like thatís your problem right there. Even if it isnít they are idiots just for doing that.
1222 is offline   Reply With Quote Quick reply to this message
Unread 12-11-2011, 01:05 PM   #9
DAYJ
Mol- Yup I think the pumps here in Ohio hate me more than those in Wyoming tho, I had to start rocking the jeep to clear the line...
1222- They claimed to have talked to the "engineers" about the problem and will discuss options when I get back to Wyoming... It's just frustrating gettin a gallon in then waiting then repeat...
Thanks yall for ur inputs... Happy holidays!!!!
Unread 12-11-2011, 01:27 PM   #10
1222
Make mine a Jeep!
1222's Avatar
A few years ago I was standing by a friend of mine with an older full sized Jeep while he was filling up for a club run. He was having the same problem as you when all of a sudden and without warning he yanked the nozzle out of his tank and threw it hard as he could to the ground while screaming f u at the nozzle. Scared the crap out of me to say the least. After a few moments he picked it back up and I started laughing out of the spectacle and have been ever since. He was in his late 50ís, which made even funnier.
Unread 12-11-2011, 01:28 PM   #11
spedly
2011 JK Wrangler
A bad evap canister or plugged vent could cause that.
Poser Jeep.
spedly is offline   Reply With Quote Quick reply to this message
Unread 12-11-2011, 01:31 PM   #12
badtux
1) There is a check valve inside the fuel tank. This isn't an anti-siphoning valve, this is a valve to keep fuel from spilling out in the event of a rollover (i.e., it's a safety valve). This valve is a plastic ball in a cage that is supposed to be pushed against a rubber seat by the pressure of the fuel in the tank when the Jeep rolls over. If the rubber seat swells in the presence of alcohol, however, the ball can press against the seat by the pressure of fumes coming up the fill hole and cause the check valve to seal. This is a long-time problem for Jeep, the only cure is to replace the tank because the seat inside the tank is part of the cage plastic-welded to the top of the tank.
2) Are you sure the dealer didn't take someone else's recently-removed defective tank and put it onto your Jeep?
3) Does it do this with every gas station and every pump? If you look at the underside of the Jeep, the filler hole is connected to a rather small hose that runs almost the complete width of the Jeep to the gas tank on the passenger side. I have no idea why they didn't put the filler on the passenger side so you didn't need such a long hose, but it is what it is. There are some gas station pumps that are sensitive to the fact that it's a rather restricted hose by comparison to most filler hoses.
4) If you switch brands of gas to a major name brand gas for a few tanks, do the symptoms get better? Some gas stations use an extra amount of alcohol in their gas, which both hurts your fuel economy and may cause swelling of the check valve. Usually (but not always) switching to a brand of gas with less alcohol will "cure" that.
Good luck!
Dog: Man's best friend. Cat: Man's weird reclusive roommate who poops in a box.
badtux is offline   Reply With Quote Quick reply to this message
Unread 12-11-2011, 01:59 PM   #13
Millermagic
Don't put the nozzle in all of the way?
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline   Reply With Quote Quick reply to this message
Unread 12-11-2011, 03:26 PM   #14
1222
Make mine a Jeep!
1222's Avatar
I donít know about that, girls arenít falling for that line anymore.
Unread 12-11-2011, 03:35 PM   #15
DAYJ
Some times i do just the tip, sometimes halfway, sometimes i slide it in and out sometimes i squeeze it hard some times i squeeze it soft, i have even let other people take it and give it a squeeze...
im likin the evap canister idea tho, i have ripped it off more than once, and its possible there could be dirt or something in the lines.... hmmmmmm... oh my evap is protected now...
thanks guys
