Wish me luck-lift going on tomorrow! - Page 2 - JeepForum.com
post #16 of 50 Old 11-24-2013, 11:45 AM
222Doc
222Doc's Avatar
the lift will not change the toe in. What ever it was it is still. you could lift it 10 feet if possible and the toe would be the same. as for the Y pipe. did you grind off the button and loosen the clamp?
As long as the shocks and or extension are no more than +2.25 in added drop over stock it will not hit the drive line.
222Doc is offline
post #17 of 50 Old 11-24-2013, 11:49 AM
krawler510
I've seen a few people with newer JKs fight that upper shock bolt and do some cutting .
So far the quickest actually goes to my buddy who loosened a few bolt mount bolts and just jacked the body up enough to get it together. 10 minutes total. Pretty cool.
'The early bird may get the worm, but the second mouse gets the cheese.'
krawler510 is offline
post #18 of 50 Old 11-24-2013, 12:01 PM
wilgeno
Bug-Out!
wilgeno's Avatar
Originally Posted by Mfrancis View Post
I have read some place that there is something tricky with the passenger front shock installation. Anyone remember this care to elaborate?
It's a tight fit to get to the top nut, but the Teraflex kit I bought came with a custom tool to get in there and git'er done.
TeraFlexed '13 Commando Green JKU Black Hardtop roll'n on 35's!
Bug-Out!
I don't always go topless, but when I do I go Commando!
wilgeno is offline
post #19 of 50 Old 11-24-2013, 12:32 PM Thread Starter
Mfrancis
2014 JK Wrangler
You may be correct, however I made the mistake of turning the tie rod adjustment instead of drag link. Does anyone know what the range is with the measure the front of the tire then the rear of the tire method? I'm looking through the threads I searched, but haven't come across it yet.
Black 2014 JKU Sport S, 6 speed manual, 3.73 rear end, 2.5" AEV Dualsport XT w/ Bilstein 5100s, 255/75/17 Goodyear Wrangler A/T, Rubicon rock rails, front grill mesh mod, Jeep door sill guards, matte black Jeep grill emblem, matte black exhaust, Synrgy upper and lower bolt swap(highly recommend), tires pending...
Mfrancis is offline
post #20 of 50 Old 11-24-2013, 12:45 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
1/8 in toe in is good. So the measurement at the front of the tire should be 1/4 in less than at rear of tire.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #21 of 50 Old 11-24-2013, 12:56 PM
krawler510
Your saying to toe each tire in 1/8"? Sounds like a lot to me. I've gone with 1/8" total.
post #22 of 50 Old 11-24-2013, 01:03 PM
HappyTrails
You are correct. 1/8" TOTAL.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #23 of 50 Old 11-24-2013, 06:04 PM Thread Starter
Mfrancis
2014 JK Wrangler
From where my measuring points were (center-ish tread groove), my measurements were 61 1/2 in the rear and 61 7/16 in the front. That is the 1/16 difference I want, correct? I also got the steering wheel straight and the esp finally shut up
Mfrancis is offline
post #24 of 50 Old 11-24-2013, 09:25 PM Thread Starter
Mfrancis
2014 JK Wrangler
Pics of the install:
Mfrancis is offline
post #25 of 50 Old 11-25-2013, 03:47 AM
duntov
Any pics of the final install done?
1998 Jeep Cherokee Classic, Chili Pepper Red, 4.0, 4WD, 3" OME Full Leaf, JKS QD, JL Sub, Sony CD w/Ipod adapter, Polk Audio Speakers, Uniden CB Radio. JCR Front Prerunner bumper, JCR Stage 3 Sliders, Reese hitch, Yakima Rack, Mopar spare tire rack.
2013 Jeep Unlimited, Gecko. Bone Stock.
duntov is offline
post #26 of 50 Old 11-25-2013, 07:02 AM
HappyTrails
Keep going! Looking good. I love watching build threads. Can't wait for the final pics.
BTW, you should probably remove the boots from the shocks, or if already installed, just take a razor to the boots and remove them. They will trap mud, dirt, sand, etc inside and eventually hurt the seals.
post #27 of 50 Old 11-25-2013, 08:47 AM
brianjw
Bilstein will not warranty shocks without boots so that's a bad idea. I had one warrantied due to a seal failure and AEV replaced it right away, after they saw a picture of it with a boot!
The boots have drains on them anyway. If rocks hit the shafts without a boot and pit them, that will destroy the seals.
brianjw is offline
post #28 of 50 Old 11-25-2013, 08:49 AM
HappyTrails
Good to know, thanks!
Disregard my last post, in that case. Keep them on!
post #29 of 50 Old 11-25-2013, 09:41 AM
JTPhoto
JTPhoto's Avatar
This problem with the front passenger side shock must be 12 and up specific, on our 07-09s there is enough room to put a box end wrench on the top nut. The factory shock body has another nut at the base of the stem to hold the shock from rotating while you loosen the nut.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #30 of 50 Old 11-25-2013, 09:45 AM
COLOUXJ
2010 JK Wrangler
Those poor brakelines!
Also not sure on the routing you have on the front brake lines. Do you have it going around the front of the shock? I cant remember where mine are routed but it would be bad if there was binding there.
COLOUXJ is offline
