Wiring question for Warn wirless driving lights. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Wiring question for Warn wirless driving lights.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenRight Offroad at CCOR! 706-207-4140Rough Country Lift Kits and Parts!
Unread 02-09-2011, 04:25 PM   #1
surfer459
I got my 6.5" wireless driving lights in today and have a wiring question. The wiring harness has a wireless reciever that picks up the signal from the remote switch. On this wireless reciever it has a power cable that needs to be connected to a power source that is on when the vehicle is on. So how do I find a good wire to connect this too for power? Or does anyone have a good suggestion of a wire to splice into? Thanks for the help, my weaknesses are wiring and transmissions!
surfer459 is offline   Reply With Quote
Unread 02-09-2011, 05:01 PM   #2
51M38
2011 JK Wrangler
Two alternatives (that I am aware of):
Quadratech sells a splice kit with instructions to connect under the dash to the aux power circuit. This is what I used for my Warn lights.
http://www.quadratec.com/products/96080_98.htm
If you do not have heated seats, and have a recent JK, there is a point to connect in the power distribution/fuse box used for the heated seat relay.
51M38 is offline   Reply With Quote
Unread 02-09-2011, 05:17 PM   #3
surfer459
The instructions say to just wire into a power source that is on when the ignition is on, as to not have a amp draw with the Jeep off. I would like to know how I find a wire that has power or not without any wiring diagrams?
Unread 02-09-2011, 08:05 PM   #4
herath
I have some Warns coming too.Is there a power source in the under hood fuse box so I don't have to run a wire through the dash.
herath is offline   Reply With Quote
Unread 02-09-2011, 08:18 PM   #5
RockyClymer
RockyClymer's Avatar
I do not believe there is an ignition switched power source under the hood that is readily available. The one under the dash is tied into the CANBUS system- but not sure what the amp rating is. I know on some JKs without some options there are some empty fuse spaces in the fuse module - might be able to plug a fuse in there and tie into it somehow. You could check and see if the ignition switch turns on power to one side of the fuse holder and this may be a quick solution - put a fuse in and then figure out how to attach to it.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline   Reply With Quote
Unread 02-09-2011, 08:23 PM   #6
surfer459
A friend suggested a voltage tester to find a wire with power after ignition. The recievers only purpose is to pick up a signal from the remote to turn the lights on so Im sure it requires very little power. When I figure it out I will make sure and post what I did, unless I get a better suggestion of course!
Unread 02-09-2011, 08:29 PM   #7
51M38
2011 JK Wrangler
The refererenced kit from Quadratech ties in under the dash without affecting the CANbus system. Amp draw is not an issue; you are not powering the lighting, only the controller. Surfer: a basic multimeter, or just a 12V test probe (any auto parts store) will tell you if the connection is switched with the ignition or not . The tap kit I referenced connects to the 12V aux outlet, which is switched.
Unread 02-09-2011, 08:35 PM   #8
herath
One advantage of the Warn suggested in other threads is it can be switched on with the vehicle off so is this correct or can it only be used when the vehicle is running?Put another way, does it function like other remotes[like remote starters].
Unread 02-09-2011, 08:37 PM   #9
surfer459
If you wired the reciever power to the battery then yes, it would work with the car on or off.
Unread 02-09-2011, 08:42 PM   #10
RockyClymer
Wouldn't that leave the receiver on all the time and add to parasitic current drain?
To clarify my earlier post - I meant the tie in was controlled by the CANBUS in that the iginition on/off
goes through the confuser and then turns the voltage on or off.
NRA Life member
Unread 02-09-2011, 08:54 PM   #11
herath
I may have to rethink the Warn and go to another system ;at least I wouldn't need the wiring kit.
Unread 02-09-2011, 08:55 PM   #12
surfer459
Off course there would be parasitic drag, which is why I dont want to wire it directly to the battery. I was just saying it could be done.
Unread 02-10-2011, 01:37 AM   #13
herath
Will the heated seat connection point interfere with CANBUS? How do you make the connection?
Unread 02-10-2011, 06:48 AM   #14
51M38
2011 JK Wrangler
Check out:
http://www.jeepforum.com/forum/f96/w...unted-1118001/
It is a good discussion of this exact subject. I have used the tap shown on this link in my 2011 Rubicon without any CANbus issues. The CANbus system monitors some circuits for high/low current (amps) limits to detect problems. Which circuits are monitored and what the limits are, I don’t know (if anyone knows of such a reference, please tell me). Most people here are doing trial & error connections and reporting what works. That is the reason why the aux power tap works, there are no apparent limits, except for the maximum wattage.
I used the tap that Green Monster suggested, a Buss Fuse part from Advance Auto, as well as the Quadratech tap kit-both work.
Unread 02-10-2011, 07:24 AM   #15
herath
Thanks for the link;I think this solved the problem.
