Wiring KC slimlights - JeepForum.com
post #1 of 7 Old 05-22-2010, 11:10 AM Thread Starter
nyrangersfan19
Hey gang, I just installed a set of KC Slimlights on the JK windshield brackets, and I'm about to tackle the wiring. I'm looking to find out the best place to thread the wiring through the firewall into the cabin. I'm going to mount the relay on the little bolt one the firewall behind the battery, unless you guys can recommend a better location?
Thanks in advance.
nyrangersfan19 is offline
post #2 of 7 Old 05-22-2010, 11:25 AM
rpjohs
I am doing the same thing, trying to figure out where on the firewall to bring them through.
rpjohs is offline
post #3 of 7 Old 05-22-2010, 01:01 PM
tclaremont
2014 JK Wrangler
Open the drivers side door.
Remove the plastic panel on the left side of the dash, facing the door.
Use a coat hanger and pierce the foam filled hole on the firewall.
Push the coat hanger all the way through to the engine compartment.
Tape wire to the coat hanger.
Pull the hanger back through the hole.
Drink a beer to celebrate.
Tim C.
Rochester, NY
tclaremont is offline
post #4 of 7 Old 05-22-2010, 01:14 PM Thread Starter
nyrangersfan19
Thanks man, I'll give that a shot!
post #5 of 7 Old 05-22-2010, 01:29 PM
DeepSky
As for the relAy I mounted mine exactly where you described.
2003 Patriot Blue Wrangler SE - RCX 2.5" Kit on 31x10.5 Firestone M/Ts and stock the rest of the way.
2007 Flame Red Wrangler Unlimited X - Skyjacker 4" Kit on 35x12.5 Cooper Discovery STT(
DeepSky is offline
post #6 of 7 Old 05-22-2010, 03:15 PM
daggo66
2009 JK Wrangler
The side dash panel will pop right off. The foam filled hole can be seen in this picture:
Tom
daggo66 is offline
post #7 of 7 Old 05-23-2010, 01:20 PM
fernjack
You can make a panel like this cheap and only have to run wires once . You then can add what you like very easily ...... just sayin'
fernjack is offline
Kc slimlights bdillon JK Wrangler Technical Forum 7 02-23-2010 03:37 PM
FActory fog light switch used w KC slimlights 2000jeeper TJ Wrangler Technical Forum 4 09-30-2009 10:46 AM
KC daylighters vs KC slimlights badazzelanore JK Wrangler Technical Forum 25 06-29-2009 04:19 PM
Wiring Windshield Mounted Lights .... Need Stock Wiring Colors ..... JHyett TJ Wrangler Technical Forum 9 03-22-2005 09:14 AM
Do the KC light locks work on slimlights? Deekins TJ Wrangler Technical Forum 1 01-07-2004 06:58 PM
